Author Topic: Dosbox Bloodwych ends before scnd dragon.  (Read 4907 times)
nrhod
« on: November 27, 2017, 05:48:02 PM »
Hi guys. Anyone's reading this anymore?
Instead of the stairs to the dragon and spider there is a wall. It shouldn't be there right? Using dosbox as the title says
Re: Dosbox Bloodwych ends before scnd dragon.
« Reply #1 on: November 27, 2017, 08:23:25 PM »
Yeah some of us still reading ;)
This is a known bug in certain PC copies - personally I would always recommend playing the Amiga version (or at least the he ST version) which are bug free and have better graphics.
I am fairly sure the map can be “fixed” with a hex editor on what you are playing though - any chance of posting the save file?
MadMunky
« Reply #2 on: November 28, 2017, 07:38:22 AM »
Still learking around also, there is a number of ways to fix it the easiest is most likely the following application
https://community.pcgamingwiki.com/files/file/946-bloodwych-welcome-back-fix/
nrhod
« Reply #3 on: November 28, 2017, 05:45:05 PM »
Thank you guys, will try it out. Also noticed trying to sell an item results in a curse. Not very kind. My guys are starving in a minute as well :D
