Author Topic: Knowing when a sample has finished?  (Read 4378 times)
Volvo_0ne
  • A1200 lover
« on: January 25, 2018, 08:47:40 PM »
OK I have several short samples which I play with Sam Raw which is just fine
BUT
How can I find out when each sample has finished playing so that I can play the next one?
This is further complicated by the particular sample to play is done by human interaction.
Think Space Invaders
TIA
V1
adrazar
Re: Knowing when a sample has finished?
« Reply #1 on: January 27, 2018, 10:16:06 AM »
FLAGS=Deek($DFF01C)
Bit 7-10 in FLAGS (counting from bit 0) tells which voices are currently being played. Each bit corresponds to one of the four voices (bit 7 <--> voice 0, etc.). If a bit is cleared it means the corresponding voice is finished, so using this you can figure out when to play the next sample :).
Volvo_0ne
  • A1200 lover
« Reply #2 on: January 28, 2018, 05:05:14 PM »
FLAGS=Deek($DFF01C)
Excellent!  I will try that tonight.
Thank you so much for your help.
V1
Volvo_0ne
  • A1200 lover
« Reply #3 on: February 18, 2018, 06:48:39 PM »
After a bit of experimenting, I realised that I could squeeze all my sample playing into 2 channels, and time the playback rather than need to detect the sample ends.
Thanks for the insight tho guys :)
V1
