Author Topic: AMIGA 1200 Raspberry pi wrong workbench keys  (Read 8496 times)
Toolkitman
« on: September 25, 2018, 10:49:31 AM »
i have an issue with a keyrah v2 i have bought, i have built an AMIGA 1200.net case with an english keyboard i have found on ebay years ago and a raspberry pi B3 with AMIBIAN, installed OS 3.1 Copper bloodwitch, my problem is that when i press  inside Workbench 3.1 the key 2 i get a 2p and when i press x i get a x and go to next line like a return. Inside Amibian interface "linux" the keybord works perfectly. What can be this issue?
Thank you for your help
« Last Edit: September 25, 2018, 10:59:09 AM by Toolkitman »
Re: AMIGA 1200 Raspberry pi wrong workbench keys
« Reply #1 on: September 26, 2018, 11:07:21 AM »
At a guess, I would say its down to the way the rasberry pi is interfacing with Keyrah.
Driver issue? Linux has better driver?
Toolkitman
« Reply #2 on: September 26, 2018, 09:05:39 PM »
Linux works fine it seems related to Amiga OS i have Copper 3.1 version of Workbench i think bloodwitch.
« Reply #3 on: September 27, 2018, 10:20:02 AM »
You can confirm this, by booting with no startup. Do keys still not work correctly?
Toolkitman
« Reply #4 on: September 27, 2018, 10:56:04 AM »
Yes i have the same problem.
Toolkitman
« Reply #5 on: September 27, 2018, 03:55:10 PM »
Like i thought seems not to be the computer because i have tried with an external usb keyboard connected directly to raspberry and i have the same issue.I think it's the OS, there is a way to solve this?
« Reply #6 on: September 28, 2018, 12:46:39 PM »
You changed locale?
Toolkitman
« Reply #7 on: September 28, 2018, 09:49:55 PM »
I tried now, it was set to english i tried with italian but i have the same issue.
Toolkitman
« Reply #8 on: September 30, 2018, 12:22:42 PM »
FOL, i tryied with the same OS image installed in fsuae under windows and the keys works fine, can be a wrong behavior of amibian uae?
Toolkitman
« Reply #9 on: October 03, 2018, 03:32:19 AM »
I have contacted the Amibian support and they say it's an emulator issue from amibian, there are more emulators to choose with the right raspberry configuration inside amibian pressing 7 on the linux interface.
I havent changed it because i have a lot of configuration just ready to go of amiga machines and i dont want to lose them.
Toolkitman
« Reply #10 on: October 07, 2018, 11:04:29 AM »
I think it's to setup the locale inside raspbian but i dont know the right configuration for amiga english keyboard and great britain locale, if anyone can help!
