Author Topic: AMOS BASIC LOGIN SPEAK [CLI EXE] + [SOURCE CODE]  (Read 2124 times)
Toolkitman
« on: October 08, 2018, 05:15:28 AM »
This is a prototype of a new AMIGA BASIC LOGIN with 2 example program, it speaks instead of write text on Screen. Put it in your DH1 hard disk install narrator if you dont have it, put the amos library into your libs folder inside your os and click over OS SPEAK inside PROVA folder click execute. Enjoy!
I have also the text version ask if you need!
« Last Edit: October 11, 2018, 08:14:02 AM by Toolkitman »
