Author Topic: [ADF] [CODE] AMIGA PROGRAM TO MAKE ANIMATED COMICS  (Read 3555 times)
Toolkitman
« on: October 16, 2018, 12:01:08 AM »
Hello,
This is my latest work, an AMIGA program to make animated Comics (a sequence of .iff images scrolling the screen in a determined time).
You can boot the floppy with a minimum conf of A500 1.3 ROM, and inside there are images i have loaded, you have to call them DF0:imm.1.iff
imm from 1 to 8, you can specify at startup a time from 1 to an unlimited number stay to basic possibility. to load new images, load the floppy inside workbench and load your .iff images made with adpro or similar at 32 color lowres 320x256 size.
There is also the source code if you want to modify it and recompile from source. Enjoy! 8)
« Last Edit: November 08, 2018, 08:14:16 PM by Toolkitman »
