Author Topic: Multibutton controller code  (Read 5380 times)
« on: August 01, 2019, 02:40:41 AM »
I just found this code on the Aminet:  http://aminet.net/package/dev/asm/ReadJoyPad
Re: Multibutton controller code
« Reply #1 on: August 01, 2019, 07:43:27 PM »
I've actually used this on WHDload slaves :)
I think some of the slave authors have made some improvements over time, especially helpful for emulation compatibility.
http://eab.abime.net/showpost.php?p=1332389&postcount=33
With AMOS i tend to just use the AMCAF commands for it , which work very well.  XFire(p,b) i think ?  (port, button)
« Reply #2 on: August 02, 2019, 04:12:59 AM »
How many buttons are supported by AMCAF's controller reader?
« Reply #3 on: August 02, 2019, 03:13:41 PM »
All 7 CD32 buttons, on both ports.
It also has Parallel port support (4 directions, 1 fire) but IIRC one of the ports is bugged / read incorrectly, so i usually end up using the ERCOLE extention for that.
« Reply #4 on: August 02, 2019, 04:06:05 PM »
That's why I asked.  I knew you had said you used another extension for port reading due to a bug in the parallel port expansion.
