Author Topic: Site fixes.  (Read 24219 times)
Site fixes.
« on: September 19, 2019, 08:13:20 AM »
Thanks for the heads up on this. Registration is now fixed. Recaptcha was using old url key.
I will update it further on weekend. In the process of fixing other stuff, like the Copyright text, as that was messed up.
« Last Edit: December 11, 2019, 09:27:04 PM by FOL »
Re: Site Registration issues.
« Reply #1 on: November 28, 2019, 07:57:03 AM »
Tapatalk is messing up now.  Can you look into it?  UltimateAmiga.com no longer shows on the listings.
« Reply #2 on: November 28, 2019, 08:36:13 AM »
Needs update, however there are lots of errrors. So will have to manually remove old and then manually install latest version. Hopefully that will fix it.
« Reply #3 on: December 04, 2019, 07:48:26 PM »
Fixed, seems some PHP code is deprecated in 5.3+. So disabled and it sprang back into life. All updated to latest version too,  ;).
« Reply #4 on: December 04, 2019, 08:09:02 PM »
Testing Tapatalk.
Is it working?
Sent from my I3113 using Tapatalk
« Reply #5 on: December 04, 2019, 08:11:12 PM »
Yes.  Replying from my cell via Tapatalk.
« Reply #6 on: December 04, 2019, 08:12:36 PM »
Great another issue sorted. Will continue working on other stuff.
« Reply #7 on: December 06, 2019, 08:11:48 PM »
Spoke too soon.  Tapatalk now says there is an invalid forum key when I try to log in.
« Reply #8 on: December 06, 2019, 08:49:52 PM »
Hmmmmm, it's working here fine.
« Reply #9 on: December 07, 2019, 07:15:31 AM »
It must have been on my end.  It's working again.
Re: Site fixes.
« Reply #10 on: December 11, 2019, 09:28:26 PM »
I have now automated the December logo. Why I never done it before is beyond me.
It should now change banner in December and change back in January.
Re: Site fixes.
« Reply #11 on: December 11, 2019, 09:33:48 PM »
Cool!
Re: Site fixes.
« Reply #12 on: January 05, 2020, 01:50:49 PM »
Nice job!  ;)
Re: Site fixes.
« Reply #13 on: March 04, 2020, 05:49:48 PM »
I can't log in with Tapatalk but can with browser.
Re: Site fixes.
« Reply #14 on: March 05, 2020, 10:15:43 PM »
You are quite correct, will look into it this weekend.
