Author Topic: AMOS Pro hangs on real A1200  (Read 3767 times)
trenkaar
« on: October 26, 2019, 07:54:01 PM »
Hi all,
I got some issue that I cannot solve. Any copy of AMOS Professional that I try (Amiga Format or downloaded from various places) hangs after a few seconds of been run. Sometimes I go as far as opening a file, but then hangs again. Most of the time hangs with the screen totally brown-ish and a cursor on the top left.
I tried with a clean 128MB CF with just WB3.1 files. I tried directly from the disks.
It works on WinUAE, but not on my A1200.
I also tested The Creator and it works.
I have an A1200 with 3.0 ROMS and 4MB Fast RAM.
People at eab.abime.net suggested that I may need a patch to make it work on an A1200? Which patch this could be?
What can be wrong? Thanks a lot in advance.
Re: AMOS Pro hangs on real A1200
« Reply #1 on: October 28, 2019, 11:07:04 PM »
Check the version number.  AmosPro 1.0 was incompatible with AGA.  Version 1.12 was better.
