Pages: 1 [2] 3   Go Down
Author Topic: Bloodwych - Book of Skulls - Official Beta Version  (Read 12463 times)
Torico
    • Youtube Account
Re: Bloodwych - Book of Skulls - Official Beta Version
« Reply #15 on: June 22, 2021, 11:18:47 AM »
lol, told my friend to drop all that Blodwyn gear, think he kept a few bits.
Hmm, can't get in the middle section, needs yellow key, haven't found a way to get to the guardian upstairs, all blocked off, we just did enough to get downstairs.
Torico
    • Youtube Account
« Reply #16 on: June 25, 2021, 03:03:28 PM »
Still can't find a way to the guardian, if you have any hints? thx
« Reply #17 on: June 25, 2021, 03:05:33 PM »
Do you still have "red, blue, yellow and iron doors with no keys" ?
If so, the floor above i think you've missed some keys in the puzzle sections. (You should have a side each, accessed from the gems)
Torico
    • Youtube Account
« Reply #18 on: June 25, 2021, 03:09:49 PM »
yea I think we got a couple of bronze keys from the puzzle rooms upstairs, and used them downstairs to get out, but didn't progress anything.
« Reply #19 on: June 25, 2021, 09:08:56 PM »
Do you have a cutpurse? I wonder if you have missed a hidden shelf...   Any chance of drawing out a small map of where you are stuck?
« Reply #20 on: June 25, 2021, 09:18:49 PM »
Just checked the maps - Through the bronze doors you should have picked up 2 more keys (one each side) Red and Green i think
Torico
    • Youtube Account
« Reply #21 on: June 26, 2021, 08:49:06 AM »
Ah, found it, we redid the Tower, there was a gem room hallway we missed, the first time I went in I got teleported from the floor tile and forgot to revisit it, doh.
« Reply #22 on: June 27, 2021, 07:30:51 PM »
Your gonna hate the Chaos tower 😂
Torico
    • Youtube Account
« Reply #23 on: June 29, 2021, 03:59:06 AM »
 ;D
Torico
    • Youtube Account
« Reply #24 on: July 06, 2021, 06:37:15 PM »
We sorta cleared the Dragon Tower, top to bottom, but are left with a chromatic key, can't find where to use it.  ???
« Reply #25 on: July 09, 2021, 12:57:42 PM »
I suspect you didnt use it on the highest level with the Arc Bolt machine. (the level before dropping into the dragon & fire pit)
I had a feeling that might happen on 2 player mode - you need it to avoid a particular floor switch, but if a player is already on the other side of the door, it might not be used.
Something similar happens in the Extended Levels with a Serpent key if i remember rightly!
Torico
    • Youtube Account
« Reply #26 on: July 13, 2021, 01:36:47 PM »
Ah k, only thing left in the tower I then is the red door at the bottom and the crystal, but haven't found the key.
« Reply #27 on: July 13, 2021, 04:50:19 PM »
It will be on either of the above two floors :)
Torico
    • Youtube Account
« Reply #28 on: July 21, 2021, 04:03:57 PM »
Ok, we made it to The Land of Entropy, killed a couple of bosses that dropped chromatic keys, and found a blue and green key, but stuck trying to find doors to use them with. Any hints? thx
« Last Edit: July 28, 2021, 07:55:34 PM by Torico »
« Reply #29 on: July 29, 2021, 05:54:51 PM »
Final Tower, huh, but still on the first floor?
Blue door is hidden; there is a clue to one of the common annoying spell puzzles of the game ;)
The serpent door should be easy enough to find - its near the arc bolt machine :)
Pages: 1 [2] 3   Go Up
