Pages: 1 2 3 [4]   Go Down
Author Topic: Issue with print #1 command  (Read 9189 times)
Re: Issue with print #1 command
« Reply #45 on: August 10, 2021, 01:24:27 AM »
The word "bank" should be deleted because it thinks it is a function or variable.  https://www.ultimateamiga.co.uk/HostedProjects/AMOSFactory/AMOSProManual/5/578.html
I assumed you had the manual.  I haven't programmed in AmosPro for a long time and was typing from memory on my phone.
Also, you have the right idea about the Peek$ function.  Just give StringLength a big number bigger than your biggest string.  As long as it finds the Chr$(0) at the end it will stop.
« Last Edit: August 10, 2021, 01:28:28 AM by SamuraiCrow »
« Reply #46 on: August 10, 2021, 01:32:37 AM »
As a non-AMCAF implementation of the encryption, substitute the following for the Bank Code lines:
For C=Start(16) To Start(16)+Length(16)-2 Step 2
    Doke C, Rol.w(Xor(Deek(C),$A55A),5)
Next C
To decode the prevous encryption:
   Doke C, Xor(Ror.w(Deek(C),5),$A55A)
Next C
If it's not fast enough, assign the end expression of the for loops (everything between the To keyword to the Step keyword) to a variable and test against that inside the loop.  Also, be sure the file is loaded before you assign the expression to the value.
This code resulted in a syntax error.
By the way the loop is fine..it crashes the second the first line of bank code xor.w 16,$a55a is executed.
« Last Edit: August 10, 2021, 01:36:39 AM by xboxisfinished »
« Reply #47 on: August 10, 2021, 02:21:01 AM »
Bank code Xor.w, Bank Code ROL.w and Bank Code ROR.w requires the AMCAF extension.  Use the loop instead.
« Last Edit: August 10, 2021, 02:51:21 AM by SamuraiCrow »
« Reply #48 on: August 10, 2021, 02:55:08 AM »
I have the extension. Even if I use the loop it returns syntax error. It would not allow me to compile.
« Reply #49 on: August 10, 2021, 03:07:02 AM »
https://www.ultimateamiga.co.uk/HostedProjects/AMOSFactory/AMOSProManual/14/1409.html
According to the manual, the 5 should come first and doesn't return a value.  The loop that had the rotate inside should be
ROL.W 5, C
Doke C, Deek(c) Xor $A55A
And the other loop should be:
Ror.w 5, C
inside the loop.
« Reply #50 on: August 10, 2021, 04:54:13 AM »
saving worked. It made a 1.7 MB encrypted file. Loading failed. It kept my hard drive activity endless working, then screen turn blue while loading and then went into software failure. Maybe because I am still using bank code. Let me try with your new code change.
« Reply #51 on: August 10, 2021, 05:05:35 PM »
The decoding is not working. It is still reading jibberish. It have failed to decode. Can you help me?
Pages: 1 2 3 [4]   Go Up
