Author Topic: Problems with login  (Read 2083 times)
AmiDARK
    • http://www.xquadeditor.com
Problems with login
« on: August 19, 2023, 12:57:57 PM »
Hello.
I encounter issue with login.
1. With Chrome I cannot login and get an error message : "An Error Has Occurred! You were unable to login. Please check your cookie settings."
But cookies are enabled and allowed for ultimateamiga.com.
2. With Firefox I can login but I get often disconnected with an error saying I <<do not have permission to access this resource>>. It happen when I try to access some AMOS forums.
AmiDARK
Re: Problems with login
« Reply #1 on: August 21, 2023, 09:34:29 PM »
It all happened when the new rules came in about cross domain cookies.
I only see first issue, when trying to login via co.uk
Second issue, is the server being over protective. I will look into all issues and start work on big updates to site.
Hello.
AmiDARK
« Reply #2 on: September 03, 2023, 11:31:04 PM »
I was only able to login by using the login link above the username/password shortcut.  If I use the username/password shortcut itself, no dice.
