Pages: 1 [2] 3 4   Go Down
Author Topic: Problem with Sensible World of Soccer '96-'97 (1996)(Renegade) on PSPUAE  (Read 54807 times)
Re: Problem with Sensible World of Soccer '96-'97 (1996)(Renegade)
« Reply #15 on: July 25, 2006, 11:30:38 PM »
super_hoops1967
if you're still struggling - try reading though this thread.... and check everything very carefully!
super_hoops1967
« Reply #16 on: July 26, 2006, 01:09:29 AM »
ok i've tried it with both these settings and still get the left mouse button screen
This First
Name   SWOS 96/97
No. Of Disks   2
PSPUAE Version tested on   0.49
Playable   YES
ADF File Name   Sensible World of Soccer 96-97 (1996)(Renegade)[cr
Hardware
Frame Skip   3
Chipset   OCS
Collision   Playfields
CPU Type   68000
Compatability   ON
Memory
Fast Mem   512KB
Chip Mem   512KB
Bogo Mem   0KB
Sound Hardware
Sound Emu   None
Snd Type   Mono
ROM Revision
KickRom   Kick 2.0
Then this
Name   SWOS 96/97
No. Of Disks   2
Playable   YES
Hardware
Frame Skip   3
Chipset   OCS
CPU Type   68000
Compatability   ON
Memory
Fast Mem   1024KB
Chip Mem   512KB
Bogo Mem   0KB
Sound Hardware
Sound Emu   None
Snd Type   Mono
ROM Revision
KickRom   Kick 3.0
and neither are working. i'm using the 2 disks that you sent me aswell (i'm using pspuae v0.52)
« Reply #17 on: July 26, 2006, 11:47:32 AM »
re-download the file i linked in your PM
i have added a save-state too it for you to try out.
works perfectly here, so i wonder if maybe your kickstarts are dodgy or something?
super_hoops1967
« Reply #18 on: July 26, 2006, 12:25:30 PM »
i'll have to get it when i get home later. is it the swos.rar that i need to redownload?
« Reply #19 on: July 26, 2006, 12:31:50 PM »
for some reason i ZIpped it this time
i am runnng it on 0.52 myself btw - so its definately not the emulator, as you suggested in the shoutbox.
i only said it worked on 0.49 in the chart because that was the easrliest version i tested it on.
super_hoops1967
« Reply #20 on: July 26, 2006, 12:40:36 PM »
ahhhhhhhh right, gotta be the kickstart files then, i'll swap them and with that savestate i reckon you'll have fixed it for me :-D
« Last Edit: July 26, 2006, 08:45:29 PM by FOL »
« Reply #21 on: July 26, 2006, 08:46:24 PM »
Super_hoops, lol, please check what you post next time, ;)
super_hoops1967
« Reply #22 on: July 27, 2006, 08:34:15 AM »
the files deffinately work because i had it running on my pda last night, i'll format my ms tonight and give it another try, fingers crossed it will work
« Reply #23 on: July 27, 2006, 10:15:27 AM »
btw - when i quit friendlies it just seems to get stuck on disk access.... although i dont get a guru.
El_MUERkO
« Reply #24 on: November 12, 2006, 11:52:31 AM »
Hi all, first post and unsprisingly its about SWOS 96/97, I can get it to run but its very choppy, any tips to improve performance would be appreciated.
« Reply #25 on: November 12, 2006, 12:07:31 PM »
turn off sound, and use the savestate from the front-page.
i'm aftraid that's as good as it gets. it's not the best running game i'll admit.  :(
El_MUERkO
« Reply #26 on: November 14, 2006, 07:13:36 PM »
cheers
it actually runs very smoothly considering, now if only the joypad and nub werent so crap, i wonder if codies will fux up the 360 SWOS, we can but hope :)
knight76
« Reply #27 on: February 14, 2007, 03:53:56 PM »
Just put the amiga em on the psp last night. Stayed up till 4am and backing up with another 4am stint. Just wanted to say thanks for the help with seni soccer settings. Got it working now.
I'm so hooked again im looking at buying an old amiga 500 again.
« Reply #28 on: February 14, 2007, 05:13:01 PM »
Good to hear, ;). Glad you got it working. Love Live the miggy, :)
Critter
« Reply #29 on: September 12, 2007, 12:37:30 PM »
after "amen" came "amega" :)
Pages: 1 [2] 3 4   Go Up
