Pages: 1 2 [3] 4   Go Down
Author Topic: Problem with Sensible World of Soccer '96-'97 (1996)(Renegade) on PSPUAE  (Read 54807 times)
buhce
Re: Problem with Sensible World of Soccer '96-'97 (1996)(Renegade)
« Reply #30 on: November 19, 2007, 10:35:30 PM »
I too am having problems loading SWOS using the latest PSPUAE 0.63. I'm getting returncode 20 and have trie many different kicks and swos.adf's. Anyone help me?
« Last Edit: November 19, 2007, 11:07:04 PM by buhce »
« Reply #31 on: November 19, 2007, 11:36:35 PM »
theres loads of dody ADFs of SWOS out there im afraid.
either keep experimenting, or use the RISS version in the downloads section.
Viperob
« Reply #32 on: January 23, 2008, 07:25:20 PM »
I can get it work no problem with the the riss file from this site but once i choose my team in career it just goes to a black screen. my mem stick flashes like crazy and i waited more than 3mins. any ideas?
« Reply #33 on: January 23, 2008, 09:25:42 PM »
the answer you seek if in the thread about the SWOS RISS funnily enough....
http://pspuae.condor.serverpro3.com/index.php/topic,452.msg4185.html#msg4185
Viperob
« Reply #34 on: January 23, 2008, 10:27:55 PM »
ahh goodstuff! sorry im still getting used to navigating round this site!
Did you finish the 07 update? that would be great!
« Reply #35 on: January 23, 2008, 11:59:15 PM »
it's ready, but it's not been compiled as a RISS yet. It will likely get done when it goes on the Amiga Online website as well.
Viperob
« Reply #36 on: January 24, 2008, 05:46:45 PM »
Can you not just up the file without the RISS format? I always change the states anyway so not to fussed
swos 07 would be superb!
« Reply #37 on: January 24, 2008, 11:18:29 PM »
editted SWOS does not fit on the original 2 ADFs.
the files alone are useless to you, as with HD support there is no way to run the game.
The only method it can be played is by creating a RISS.
please be patient, i will try to get it done very soon.
Viperob
« Reply #38 on: January 25, 2008, 04:22:18 PM »
Ah right i see. OK then good luck with it all horace.
EmuChicken
« Reply #39 on: January 29, 2008, 09:40:38 PM »
how about them "custom" adf files that you can make larger than 880kb? ;-)
« Reply #40 on: January 29, 2008, 09:44:13 PM »
They can be quite unstable, depends on how mem state uses I suppose.
« Reply #41 on: January 29, 2008, 10:16:42 PM »
you dont need custom ADFs for dos disks, just high-dens. But i would be surprised if SWOS operates like a completely normal dos disk, since the game doesnt even let you speed up the drive without crashing.
anyway, the RISS got  made and uploaded. all those requests and demands for an updated version, and there's been 10 downloads and only 1 thanks.
i do kinda wonder why i bothered.  ::)
« Last Edit: January 29, 2008, 10:19:29 PM by Hungry Horace »
Gazman
« Reply #42 on: February 17, 2008, 06:48:35 AM »
You're right. It doesn't take much to say thanks instead of taking it for granted, so....
Thanks man
« Last Edit: February 17, 2008, 09:39:50 AM by FOL »
« Reply #43 on: February 17, 2008, 10:42:25 AM »
Thanks man
Sure, that will make horace happy, :).
« Reply #44 on: February 17, 2008, 01:53:51 PM »
32 to 2.  ;)
hope you're enjoying the new teams and graphics gazman!
Pages: 1 2 [3] 4   Go Up
