Author Topic: Floppy Speed not saving  (Read 6473 times)
ParaSitius
  • Swish
    • ParaSitius.com
« on: August 12, 2006, 07:27:07 PM »
Just tried saving my preferred Settings and have discovered that Floppy Speed is one option that keeps defaulting to 100% even when I try saving it set at 800%.
Re: Floppy Speed not saving
« Reply #1 on: August 12, 2006, 07:50:56 PM »
Me thinks you got wrong version?
You using 053 beta? or something?
Also there aint an 800% option, its Turbo, as 800% kills emu, :(
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #2 on: August 12, 2006, 09:43:37 PM »
Yeah, using 0.53 and the emu works fine when the 800% option is switched on.  I thought the 800% was the Turbo option, hmm very strange.
« Reply #3 on: August 13, 2006, 08:42:22 AM »
Does it actually state 100% and 800%, cause if it does you got my version, which was then tidied up by Ric.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #4 on: August 13, 2006, 11:27:09 AM »
That's the one, think I have the proper Turbo version on my 32mb card while yours sits on my 4gb hdd.
I assume just replacing the eboots will sort it out?
« Reply #5 on: August 13, 2006, 12:07:14 PM »
Correct, replace the eboot, in the __SCE__PSPUAE folder.
Remember that was a beta version, of mine, which didnt save the option. Ric fixed that and tidied it, then it was released.
