Author Topic: PSPUAE 0.53 (GTA Eloader Version)  (Read 22509 times)
0 Members and 6 Guests are viewing this topic.
« on: August 12, 2006, 09:17:46 PM »
Same as PSP V1.50, but runs on PSP V2.+ ONLY
I have tested it on my V1.50 Emulating V2.60 and using GTA E-Loader to load it.
Hi, we have released a new version (0.53), this is a small update,
v0.53
- Drive Speed option added (This helps alot with long loading games, it wont help with all)
« Last Edit: November 13, 2006, 08:02:37 PM by FOL »
ParaSitius
  • Swish
    • ParaSitius.com
Re: PSPUAE 0.53 (GTA Eloader Version)
« Reply #1 on: August 12, 2006, 09:51:31 PM »
May want to see if you can put the file at the top of the Download page in case people accidentally download the 1.50 version.  Fairly common for people not to read the descriptions properly and then post saying it won't work.
« Reply #2 on: August 12, 2006, 11:20:58 PM »
have posted it on dcemu.... that should get the word around!
Amiguero
« Reply #3 on: August 13, 2006, 11:30:01 PM »
Thanks FOL, I'll try it soon.
Cheers
Amiguero
« Reply #4 on: August 14, 2006, 09:23:40 PM »
amigaworld.net the last news..for us
http://www.amigaworld.net/
and this greek site..
 ;D
http://www.octapus.net/phpnuke/index.php
« Last Edit: August 14, 2006, 09:41:37 PM by Anemos »
« Reply #5 on: August 14, 2006, 10:37:14 PM »
 ;D
lol, did i spot Anemos`s name on last site, ;).
« Last Edit: August 14, 2006, 10:41:50 PM by FOL »
« Reply #6 on: August 14, 2006, 10:52:21 PM »
Heres some info, as found out by DefiantPSP over at DCEmu UK.
If your having problems with PSPUAE (GTA E-LOADER) Version, try reinstalling E-Loader, as this solved the problem for DefiantPSP. It booted fine, but kept freezing and crashed his PSP when he put an .adf in.
If your still having problems, please make sure you have a working KickStart. As PSPUAE will only boot you back to the PSP XMB if the KickStart is wrong name/ missing or damaged.
Also, should have pointed out that using the GTA method, you will find that PSPUAE will crash if you set the memory above 1 to 1.5 Megs, I havent confirmed a true crash value as yet, but will post once I have run some tests.
« Reply #7 on: August 14, 2006, 11:39:58 PM »
i am
 ;D ;D ;D
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #8 on: August 15, 2006, 12:13:05 PM »
Heh, seems that one of the main News posters on psp-hacks.com called Greg is a fan of PSPUAE.  Check the Easy Emu Nstaller piece from yesterday :)
« Reply #9 on: August 15, 2006, 05:31:21 PM »
Nice to see the people wanting this out weigh the people slagging it off.
