Author Topic: PSPUAE won't accept my ROM's  (Read 9001 times)
KidCactus
« on: August 13, 2006, 05:45:59 PM »
I have all the valid ROM's, bought from Cloanto and they work just fine in my emulator on the PC, but even though I set everything up as it should be set up, PSPUAE won't start and just goes back to the PSP OS. Why!? I'm using version 0.53.
ParaSitius
  • Swish
    • ParaSitius.com
Re: PSPUAE won't accept my ROM's
« Reply #1 on: August 13, 2006, 06:00:33 PM »
You've definetly renamed the ROMS as kick13.rom, kick20.rom etc?  And they are also in the PSP\GAME\__SCE__PSPUAE\ directory?
KidCactus
« Reply #2 on: August 13, 2006, 06:14:57 PM »
Absolutely. Everything looks like it should according to the readme, and the ROM's are valid. Really annoying, I must say, since I have no idea what to do.
« Reply #3 on: August 13, 2006, 06:28:44 PM »
Well it definately the Roms, as thats the only reason PSPUAE will boot you back to XMB.
KidCactus
« Reply #4 on: August 13, 2006, 06:35:04 PM »
Yea, I'm sure it's the ROM's causing it then. But since my ROM's ARE valid and working elsewhere, I'd say something's wrong with PSPUAE.
« Reply #5 on: August 13, 2006, 06:36:56 PM »
I thought the Clanto roms were edited in some way, to work with only the Clanto Amiga Forever.
KidCactus
« Reply #6 on: August 13, 2006, 06:42:30 PM »
But isn't Cloanto using standard WinUAE or WinFELLOW? Anyway, I've downloaded Fellow from another site, and the ROM's worked in that too.
« Reply #7 on: August 13, 2006, 06:45:37 PM »
Well as the roms you quoted are 256kb in size id say they are not standard.
KidCactus
« Reply #8 on: August 13, 2006, 06:48:27 PM »
But that's only legal ones (?) you can get hold of without owning the hardware...
« Reply #9 on: August 13, 2006, 07:57:51 PM »
Yeh, we all know you can get hold of them, just of matter of searching. I thought clanto bought the rights to the kickroms, and any further developemnet of them. My CD32 Kickrom works fine, as its just a 3.1 and the extended makes the CD32 Version.
