Author Topic: 0.54 Bug List  (Read 4284 times)
0.54 Bug List
« on: September 09, 2006, 02:21:37 AM »
0.54 Bug List
not too much to put in here anymore, so if anyone posts on the thread i'll add to an updated list here.
OSK
pressing X on OSK presses fire (or mapped key) in emulation also
Utility (settings etc)
Memory leak (?) occuring when switching from smaller to larger savestates. PSPUAE runs out of memory and needs re-loading in order to load the larger saves.
Emulation
Running at 60fps in PAL mode (confirmed as PAL mode when attempting to put WHDload into NTSC mode)
All memory settings of greater than 2 meg (need to check this value) fastram appear in workbench as 4 meg fast.
3 meg and some something-and-a-half meg settings also crashe when accessing the memory. suggest removal an allowing for only 0, 2, 4 meg fast. (1 and 3 if above bug can be fixed)
« Last Edit: September 13, 2006, 09:51:08 PM by Hungry Horace »
