Author Topic: PSPUAE 0.55 Released  (Read 8207 times)
« on: September 12, 2006, 06:09:41 PM »
This new version, is thanks to MrModem, who made some nice additions to the massive update by Ric that is PSPUAE 0.54.
V0.55 - MrModem Update
 - Added some more Joystick mapping options. You can now use any button to control Amiga
   joystick 0.
 - Changed all sceCtrlReadBufferPositive to sceCtrlPeekBufferPositive. This should speed things up a
   little, because sceCtrlReadBufferPositive always waits for vsync.
 - Fixed a "bug" that caused the PSP to crash if you tried to exit using the home button.
 - Added Bilinear filtering when zoom is turned on.
« Last Edit: November 13, 2006, 08:08:46 PM by FOL »
Re: PSPUAE 0.55 Released
« Reply #1 on: September 12, 2006, 07:03:28 PM »
decided to release it hey?
any of your own modiffications in this FOL?
« Reply #2 on: September 12, 2006, 07:05:36 PM »
No, my added options, might not do anything, im still looking at it, need to add the options to menu, so i can test on the fly. Which should hopefully let me see any difference.
Give me 20 mins, ill FTP it, so you can help me test it.
Feark
  • HE JUST LEFT....WITH NUTS
« Reply #3 on: September 12, 2006, 08:31:01 PM »
Great! Thanks! All the thumbs is pointing up! Well, atleast both of them.
Amiguero
« Reply #4 on: September 13, 2006, 08:35:39 AM »
Good on you guys! I'm very impress with progress and effort put into this project.
Cheers!
Amiguero
