Author Topic: keyboard error  (Read 7193 times)
cleanoff
keyboard error
« on: September 14, 2006, 04:14:21 AM »
Has anyone else noticed that when setting the zoom level to anything but 0% the keyboard won't come up anymore ??? i'm gettin a tad frustrated changing zoom modes just to bring up the keyboard, press a key, then put the zoom back... :'(
I'm using the latest version55 - great job on bilinear filtering when zoomed  ;D looks awesome - yummy n smooth  ;D
Re: keyboard error
« Reply #1 on: September 14, 2006, 11:12:45 AM »
hmmm.... id this not already on the bug-list? if not it may have ben preferable for you to have just posted on there.
i'll update the list to 0.55 later and check that this is added. it's certainly been mentioned in the chatroom on occassion.
Re: keyboard error
« Reply #2 on: September 14, 2006, 10:42:12 PM »
Yes, i brought this up, if zoom or Direct VRAM is on, then the keyboard is buggy ONLY on certain things though
Re: keyboard error
« Reply #3 on: September 15, 2006, 07:27:36 AM »
try .. in game change the virual memory on-off  , this fix operate kayboard! , test it.
Re: keyboard error
« Reply #4 on: October 03, 2006, 06:49:13 PM »
This will be fixed in the next release.
