Author Topic: Some Pointers regarding diff versions  (Read 4903 times)
« on: July 11, 2006, 12:26:09 AM »
I have been seeing alot of people jumping in and posting, this dont work that dont work, all over different sites. I think I made the readme very understandable, It explains everything.
So, heres the version info.
All versions up to 0.41 are for PSP Firmware 1.50
V0.41.1 and V0.49 are updated by Ric to work with the GTA Exploit on PSP Firmware 2.x + (WILL NOT WORK WITH TIFF EXPLOIT).
V0.51b updated by Ric is for PSP Firmware 1.50 (WILL NOT WORK WITH TIFF or GTA ELOADER).
Obviously Firmware V2.70 and V2.71 arent able to run any homebrew at all, so this wont work for people with this Firmware Version.
NOTE:- I have modified the description in the downloads stating what each version is compatable with. If you still get problems then make sure you have a good kickROM file, as I have tried every version here and they all work fine.
People have been wondering whats with the __SCE__ folder prefix, if your new to 1.5, you need 1 folder with the main eboot and the other with the HB app eboot. Using __SCE__ is a much easier way to hide the corrupt folders in the GAME dir. Basically keeps your PSP MENU tidy.
« Last Edit: July 11, 2006, 12:48:37 AM by FOL »
