Author Topic: E-Loader 0.99 (New Tiff Exploit)  (Read 4285 times)
« on: October 04, 2006, 09:16:03 PM »
There seems to be an issue with the new Tiff Exploit and PSPUAE.
PSPUAE will boot fine, and run fine as long as the following isnt changed from there defaults.
Memory, this will only work as 0KB Fast, 512KB Chip and 512KB Bogo (if the memory is changed, PSPUAE will either boot fine, then crash the PSP upon inserting a floppy or crash the PSP straight away).
Direct VRAM option, if this is set to ON, then you will see nothing, just a Blank Screen.
Default Values
Memory
Fast = 0KB
Chip = 512KB
Bogo = 512KB
VRAM Option
Direct VRAM = OFF
For the best results, run PSPUAE using the GTA Eloader.
« Last Edit: October 04, 2006, 09:19:27 PM by FOL »
Re: E-Loader 0.99 (New Tiff Exploit)
« Reply #1 on: October 20, 2006, 09:40:32 PM »
Have been doing some more testing, with the tiff exploit.
I have updated the Readme to include the updated memory maximum`s.
Total memory allowed is 4 Megs, anything over that and the PSP will crash.
« Last Edit: October 21, 2006, 10:50:52 AM by FOL »
