Author Topic: PSPUAE Current BETA NEWS  (Read 5371 times)
« on: October 18, 2006, 08:00:16 PM »
Hi, just thought I would post to keep you all up to date as to whats going on with the current BETA for next version.
Features include
 - new autoframeskip logic with fps limiting for both PAL and NTSC
 - real 4 channel stereo
 - fixed a couple of menu bugs
 - Immediate Blits (Helps with compatability)
 - Blitter Cycle Exact (Helps with compatability)
There might be more added / improved, but cant say as yet, as its still being tested.
The first feature, when Auto Frameskip is set "ON", then PSPUAE will now keep as close to 50 FPS as possable. This will avoid speed up and slow down, it might not be 100%, but its damn close.
The second, well there was a problem with the sound emulation, and what was thought to be stereo and 4CH wasnt. Ric has now fixed this, and 4CH sounds awesome.
The last, this is to do with the newly implemented MENU system from the first BETA. Ric has fixed some problems to do with the way the MENU behaves after selecting options (i.e. leaving lines on the screen where it shouldnt).
Id like to thank Ric for continuing to update PSPUAE, to the fine emulator with have before us. Also to all the BETA testers that have been helping test the current BETA.
« Last Edit: October 18, 2006, 08:09:25 PM by FOL »
Raventyr
Re: PSPUAE Current BETA NEWS
« Reply #1 on: October 19, 2006, 02:57:54 PM »
Awesome, can't wait for the release !
~ MMMM Brainsss ~
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #2 on: October 19, 2006, 11:49:51 PM »
Superb ain't it.
Can't say how much I appreciate the hard work that everyone has put into the project over the last few months, the day that perfect (or as close as the psp will allow) emulation finally arrives can't come soon enough.
LONG LIVE THE AMIGA - BEST HOME COMPUTER EVER MADE
AND LONG LIVE PSPUAE - BEST EVER EMULATOR EVER MADE!!!!
« Last Edit: October 19, 2006, 11:55:36 PM by ParaSitius »
