Author Topic: WMP/Quicktime friendly radio sites?  (Read 5001 times)
ParaSitius
  • Swish
    • ParaSitius.com
« on: October 24, 2006, 11:50:52 AM »
Due to lack of admin access where I'm currently working, I'm unable to listen to the radio on this site or Amigagames.com as I can't install anything.  Any sites out there that make use of Media Player or Quicktime? (which are installed on the pc i'm using).
Re: WMP/Quicktime friendly radio sites?
« Reply #1 on: October 24, 2006, 06:00:47 PM »
ParaSitius, just for you I will make a playlist, so you can use Media Player, ;). Need to sort pspuae.com out first.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #2 on: October 25, 2006, 06:34:06 PM »
Swish.
 ;D
