Author Topic: pspuae 0.61  (Read 5252 times)
thinkp
  • PSPUAE DEV
pspuae 0.61
« on: November 02, 2006, 05:57:43 PM »
Hi there!
I downloaded the source a few days ago and made some improvements to make pspuae more comfortable.
What's new:
- optionfiles with names (name_of_the_disk.options)
- savestates with names (name_of_the_disk.asf)
- auto-save options when saving state (in folder STATE )
- auto-load options when loading state (from folder STATE )
- auto-load options when inserting disk
- assign keys in controls menu with amiga keyboard
  (press square to open/close keyboard and cross to select, triangle to delete button)
- assign keyboard keys to the 4 d-pad directions in combination with the l+r shoulder buttons
  (set 'Directional Buttons' in controls menu to 'Keys')
- mouse speed option in hardware menu (from 5 [fast] to 1 [slow])
- hi-res mouse speed option in hardware menu (from 5 [fast] to 1 [slow])
- dual joystick control - same joystick on d-pad AND the analogue stick
You can download the new version from the link below, i also included the changed source files.
LINK REMOVED, AS IT WILL BE UPLOADED TO DOWNLOADS SECTION
Have fun with the new pspuae!
« Last Edit: November 02, 2006, 10:42:00 PM by FOL »
Re: pspuae 0.61
« Reply #1 on: November 02, 2006, 06:59:17 PM »
This is abit un-expected, but this is great, I have been working on this for the past week. but you have done it first (im a n00b with C, so trying to learn as I go). Ill add it and the source to downloads (well would if I could get it). It will not let me download it, says im already downloading a file or invalid session, :(.
What not having disk in floppy? as I use custom savestates, that have no floppies in the drive, so it cant name after that. I was looking into browsing the STATE folder like the insert disk folder does. So I can throw as many renamed SaveStates in the STATE folder as I want, and it would show in the state menu and you could load them.
EDIT:- I really hate RAPIDSHARE, it never ever works. first it says wait 40 secs, then click, then it tells me im already downloading. I leave it, try again, then it tells me to come back in 77 mins. Its like "HELLO, I HAVENT DOWNLOADED JACK".
« Last Edit: November 02, 2006, 07:14:39 PM by FOL »
thinkp
  • PSPUAE DEV
Re: pspuae 0.61
« Reply #2 on: November 02, 2006, 08:35:35 PM »
Hi FOl
you can browse the state folder and load the savestates, see pic.
when there is a disk in floppy the savestate has the name of the disk.
at the moment you can only save one named state, but i want to change this.
here is a picture of the new extended controls menu.
i could download this file (and many others) from rapidshare without problems.
Re: pspuae 0.61
« Reply #3 on: November 02, 2006, 08:55:28 PM »
No probs I managed to get it, I tricked RapidShare into letting me download it in the end. Ill add the new dir structure I added to the current source, then I moved on to named save states, I tried using the scan DISKS dir code, but got way lost. lol, you have added some of the stuff that was on the to do list, ;D.
Ill give it a try, and then upload to downloads section.
Re: pspuae 0.61
« Reply #4 on: November 02, 2006, 10:07:58 PM »
oh great.... two versions to try out which i havent yet, because i've been too busy playing GTA!!
ThinkP... great work, and welcome to the team. I hope you'll communicate with everyone else so that everyone can keep versions consistant, and everyone can work on the areas of their own expertise.
with 4 people now working on pspuae, development seems to be coming along great!
