Author Topic: Cannot get PSP-UAE to run on my newly downgraded PSP!  (Read 17717 times)
Re: Cannot get PSP-UAE to run on my newly downgraded PSP!
« Reply #15 on: July 15, 2006, 09:17:39 AM »
FOL what options require to restart the emulator?
Sorry, not sure I understand your question?
If you mean when changing options, which ones require a reboot of the Emu,
Below are the options that can be chenged without reboot,
FrameSkip = 3
Direct VRAM Access = ON
Zoom = 0% (Cant be used if above option is "ON")
Sound Emulation = Normal
Stereo = Mono
Show LEDS = ON
Below are options that shouldnt be changed unless you reboot,
Chipset = ecs_agnus
Collision Mode = Playfields
CPU Type = 68000
CPU Compatability = OFF
FastMem = 0KB
ChipMem = 512KB
BogoMem = 512KB
Kickstart = 1.3
You can change all options without a reboot, but for the HARDWARE items, its not a good idea.
Exoskeletor
  • PSPUAE Site Staff
« Reply #16 on: July 15, 2006, 09:20:23 AM »
Thanx
Live And Let Die
Amiga Will Never Die PC User
