Pages: 1 ... 5 6 [7] 8 9 ... 18   Go Down
Author Topic: Wanted RISS for PSPUAE  (Read 209590 times)
TheRealSlim_Mafoo
Re: Wanted
« Reply #90 on: July 16, 2007, 03:44:39 PM »
Do you think it's possible for a titus the fox R.I.S.S., the game runs beautifully however the loading times are a pain.
Couldn't you load up the game, then save the state yourself? Thats what I did with SWOS once my career was going (it didn't like starting a career from the savestate downloaded from this site for some reason).
Re: Wanted
« Reply #91 on: July 16, 2007, 03:53:35 PM »
If you save state from an adf, then you need both the adf file and the savestate on your MS, plus the loader loading times cause your using the floppy. A R.I.S.S. will give you 1 file (and a config), with no need for adf anymore and the loading is faster.
Did you have CPU CYCLE EXACT set to on in the CHIPSET menu, as this is a know problem, SWOS needs this turned on or it crashes when using career mode.
« Last Edit: July 16, 2007, 03:55:24 PM by FOL »
TheRealSlim_Mafoo
Re: Wanted
« Reply #92 on: July 16, 2007, 04:23:50 PM »
Dunno- I tried it my way, and it worked!
Re: Wanted
« Reply #93 on: July 16, 2007, 05:09:27 PM »
i will be making a new SWOS save-state anyway probably, hopefully finally laying this problem to rest.
however, atm i have other new states to concentrate on!
Keane
Re: Wanted
« Reply #94 on: July 16, 2007, 08:41:56 PM »
I would like to Request savestates for:
Qwak by Team 17
Lionheart
Project-X
Assassin
Cheers
Re: Wanted
« Reply #95 on: July 16, 2007, 09:10:05 PM »
I dont think Lionheart will be very playable, but I shall do it if no-one is on it.
Re: Wanted
« Reply #96 on: July 16, 2007, 09:31:58 PM »
Qwak by Team 17
Lionheart
Project-X
Assassin
Cheers
Project X (CD32) and Assassin are already done and in download section
Re: Wanted
« Reply #97 on: July 16, 2007, 09:36:15 PM »
Thought I would point this out, when you load the states, if its using chipset speed, check it, as it might default to 31% if its a 0.62 state. Up it to 85% and then see how it goes, if not just adjust it some more either way.
Also, you might have to adjust the FS, as it might run to slow or fast, use atuo FS.
EmuChicken
Re: Wanted
« Reply #98 on: July 16, 2007, 10:37:13 PM »
what gives the best performance usually?  ... 85 or 93?  ...  isnt higher better in this case?
Re: Wanted
« Reply #99 on: July 16, 2007, 10:54:37 PM »
depends on the game - some stuff hates it being put that high!
sappo
  • Amiga Fanatic!
  • Amiga Fanatic!
Re: Wanted
« Reply #100 on: July 16, 2007, 11:09:09 PM »
Thank you FOL :D Sorry if I posted about it also on the Shoutbox  ;D
If its an AmiDOS loading game, then you dont need WHDLoad to run it, WHDLoad just makes it easier.
especially if the game has a codewheel/manual copy protection etc... as i dont trust the cracked versions to be bug-free!
It only has a manual copy protection after a while that you have started a new game.
Quote from: Wikipedia
Amiga version itself was ported from PC and due to a lack of reprogramming it was very slow.
I hope Wikipedia refers to the 4 floppy version ;D
I haven't never personally tried HD version. I think I will get a look at it with WinUAE :P
Re: Wanted
« Reply #101 on: July 16, 2007, 11:44:48 PM »
if it has manual protection at -any- point, i would recommend the whdload installer is used rather than a cracked copy myself... but since FOL will be making it, and not me... its his choice!
Keane
Re: Wanted
« Reply #102 on: July 17, 2007, 12:10:06 AM »
Ah sweet, never thought to look at the CD32 section for Project-X
sappo
  • Amiga Fanatic!
  • Amiga Fanatic!
Re: Wanted
« Reply #103 on: July 17, 2007, 01:18:33 AM »
Yeah, but... There's no WHDLoader installer on WHDLoad support site :P
So, I'm even thinking of doing the R.I.S.S. myself (not so much problem, after reading your guide, Horace :) ) but now I have a doubt...
If there's not WHDLoader installer, can I make something like this?
1) Install the HD version of the game in WinUAE in an emulated HD
2) Follow the standard procedure, but this time, I lha the HD files
3) Create a startup-sequence on the first ADF where it extracts all in RAM
4) Always using the startup-sequence, try to start-up the game like a normal HD installation, but this time from RAM
5) If all goes well, Save-State :)
What do you think, guys? It's possible? :)
Maybe I should just try it myself :)
« Last Edit: July 17, 2007, 01:20:07 AM by sappo »
Re: Wanted
« Reply #104 on: July 17, 2007, 01:36:43 AM »
yeah - sounds right - make sure you post it for us all here!
no whdload slave huh?  must be a rubbish game... hehe
seriously though, id use a cracked copy to install from tho :S
Pages: 1 ... 5 6 [7] 8 9 ... 18   Go Up
