Well i think we should, if you say that it would really help us.
But it's up to you guys, I'm doing fine with my states for now. coming along a little slow albeit.
have had a full weekend, with birthdays, and some overtime at work.
well it would be easy for us to "refresh" your states ourselves with the new beta, but if FOL is ok with it, then i think you two should have it. (saves us that bit of extra time!)
please can you post which staes you've done, and which ones you have planned, as i'd really like to avoid any cross-over. (same goes for you FOL, i see only a list of "done" states
) - glad to hear its going well tho Firestar
Nothing wrong with my done states, I am posting as I do them, when I have done what I have, i will check to see what others have done and avoid them.
EDIT:- Seems im was half asleep and done some already there, but hese are done on the new BETA, let me know if you want em though.
I aint got a problem with it, but both need to understand, we would be handing them trust, as its a beta,
. Best to ask Ric and thinkp first though.
