Author Topic: GAME COMPATABILITY LIST  (Read 25557 times)
TheAgent
« on: November 18, 2006, 03:16:05 AM »
To start with ill say hello to all
well, iv been over the boards now for the past 4 hours, reading here and there, yet haven't really seen any game compatibility list going on, so i thought id start one, any posts that get added, ill up date this main post, ill try and keep it in alphabetical order as well
my setting for testing games are as follows
KICKSTART:
Work bench 3.1
HARDWARE:
CPU TYPE: 68020/68881
CPU SPEED: max
Chipset: ecs_agnus
Fastmem size: 512kb
Chipmem size: 2048
Bogomem size: 1024
Floppy speed: Turbo (some times have to set it to normal to get games to run)
DFO Disk type: 3.5 DD
DF1 Disk type: 3.5 DD
Mouse speed: 3
Hi -res mouse speed: 1
VIDEO:
Frame skip: auto
Zoom: 0%
Direct VRAM: on
Collision mode: playfields
Immediate blits: off
Blitter cycle exact: off
Show leds: on
Transparent keyboard: off
AUDIO:
Sound emu: normal
Stereo: mono
KEY:
(1) = works great, albeit with stuttering sound (though i know this is still being looked at)
(2) = noticeable frame-skipping with some slow down
(3) = in game, yet very slow, still playable if you can cope with the speed
GAMES LIST TESTED AND WORKING:
AlienBreed (2)
AlienBreed 2 (2)
AnotherWorld (1)
Cannon fodder (3.5 disk version) (2)
Chaos Engine (2)
Frontier Elite (3)
International Karate (1)
Monkey Island - The Secret of Monkey Island (1)
Monkey Island 2 - Lechuck's Revenge (do not use zoom, as it reverts to 8bit colors) (1)
Moonstone (1)
Speedball 2 (2)
Turrican 2 (2)
UFO: enemy unknown /  defence (depending where you come from) (3)
GAMES LIST TESTED AND NOT WORKING
*disclaimer*
Although i have tested these games and could not get them to run, even under different set up options, does not mean that they are not compatible, if there is a game in this list that you know to work, then please let me know and i can then add it to the working list
Akira
Alienbreed 3d
Alienbreed tower assault
Beneath a Steel Sky
Cannon fodder 2
Eye of the beholder
Eye of the Beholder 2
Flashback
Ghosts n Goblins
Gloom
Populous 2
Predator
SpaceHulk
Testdrive
The Settlers
The Lost Vikings
Turrican
Turrican 3
Utopia
Valhalla
Walker
« Last Edit: November 18, 2006, 03:20:16 AM by TheAgent »
Re: GAME COMPATABILITY LIST
« Reply #1 on: November 18, 2006, 04:00:44 AM »
err...  we do have one already ;)
ctrl- F on the front page, and you''ll be able to search for "PSPUAE Game Compatability DataBase"   on there. i think its open for all to add to .. .(not beng a fan of ADFs i must admit to being poor at adding to it)  . it's probably just "folded away" (little white triangle right hand side of it)...
i would say more, but it's very late/early
TheAgent
« Reply #2 on: November 18, 2006, 04:10:11 AM »
I'm either going blind in my old age, or I'm missing something in my window, i can find the comments and posts about it, i just cant find "it", if that makes any sense what so ever...
(and yes, you are right, its way too early in the morning)
anyway, i shall continue my search tomorrow, as its now 5:09am and i need to put this psp back on charge, lol
*EDIT*
OK, I'm losing it, it wasn't there a minute ago, but now it is? Oo
well... er... dunno then, delete this post if you want, or i could carry on, just in case people miss the ones on the front like i did?. let me know please :)
« Last Edit: November 18, 2006, 04:14:35 AM by TheAgent »
« Reply #3 on: November 18, 2006, 08:51:03 AM »
*EDIT*
Only registered members can see it, but server is playing up at the moment, as you can see from my last news post, lost to 2 days some how, :(.
knight76
« Reply #4 on: February 16, 2007, 02:13:10 PM »
Hmm, strange. I set my em up to these specs and could not run speedball2 at all. Would not even load it. Just black screen forever.
« Reply #5 on: February 16, 2007, 04:09:05 PM »
Try the savestates on the right side of main page, they come with config files, so you just load it via state and it sets it all up for you. Thats only horace's states though, mine havent been updated.
knight76
« Reply #6 on: February 16, 2007, 11:58:50 PM »
Thanks FOL.
Just out of curiosity. Are your base settings for testing the same as above?
« Reply #7 on: February 17, 2007, 12:20:04 AM »
Thanks FOL.
Same as above?
« Reply #8 on: February 17, 2007, 10:11:01 AM »
Knight, they may be the same or similar, but the chap who posted those settings is not an official pspuae overlord ;), but from what i can tell, it is pretty standard. Dont forget  about the drives being in turbo or normal, ive found a few games wont work with this on at all, so its usually the first thing I try solve if I have any compatiblity problems.
My suggestion is try the lowest possible setting for ur games, which i would think is basically an A500 and if they dont work then try changing things like memory, kickstart,CPU registers and speed, etc.
« Reply #9 on: February 17, 2007, 10:47:41 AM »
Thanks FOL.
Ah, thanks skate, i now see, lol. Those settings posted are damn close to my state config, just change the Kick to 3.0 and it will be the same, all my state will work from that config.
knight76
« Reply #10 on: February 17, 2007, 12:47:26 PM »
Thank for the advice.
Ill use these settings as my base for testing. I also set my kick to 3.0. Of course I will check the states on the main page before I do anything  ;)
« Reply #11 on: February 17, 2007, 12:50:24 PM »
Oh, ment to say, some states crash, on first load, just load them again, and they are fine. Horace thinks this could be some sort of memory leak.
EmuChicken
« Reply #12 on: February 18, 2007, 04:45:08 AM »
Ah, yeah-  make sure when you load these states on the site, its kickstart 3.0... but if you use adf's , make sure that the kickstart is chosen for the game... as a rule, old games > kick 1.3, new games > 2.0+
knight76
« Reply #13 on: February 18, 2007, 06:32:45 AM »
Cheers for the advice guys.
The Evolution Of Life
« Reply #14 on: October 13, 2007, 06:23:14 PM »
Just loaded Drip/Megaball, it works first thing but when you press F1 or F2 on the Keyboard it still stays in the menu.
Not sure if it's a glicth in the PSPUAE Keyboard, or if the PD Games themselves are not Compatable.
3.90M33 PSP Phat
0.63 PSPUAE
1GB Pro Duo Memory Stick
No Loaders Just CFW
