in the wake of the recent Moonstone requests, i have created a little AMOS frontend thing, for any games which are limited because of WHDload registration.
I've created some Supremacy Boot Disks, for anyone to look over (FOL, you may want to see what i've done here)
download hereedit... actually, i've improved my methods slightly by the time i did Pinball Dreams. You can
download that hereI've also created a package for the frontend as a ZIP, this includes;
WHDBoot.exe - the front-end itself
2001.font & 2001/8 - the font used by the frontend, which needs to be located at a "WHD:" assign
diskfont.library - required to be in LIBS: for it to run without a memory error
execute - the WB command which must be in C: to run the script
game-startup - a template game-startup script, this is what the frontend runs - leave it in the same place as the frontend itself
system-configuration - place this on the boot disk, and DOS will use a black background - this makes things look a little nicer (no flicking to grey) when the fontend & whdload switch between one another.
so basically, the zip contains all the extra bits you may need in order to "bolt on" the frontend to any previous ram-install disks.
download herethe front-end looks like this:
i have also uploaded the Supremacy save-state for everyone to try out!
(check the downloads section people!!)
