Author Topic: exult  (Read 5211 times)
raskolnikov
exult
« on: November 29, 2006, 07:11:43 AM »
is it possible to get exult port to work on workbench 3.1... i'm not sure how to load it.
any help would be greatly appreciated.
i have an info file and an exult folder with more info files...i have managed to boot up workbench 3.1 but i don't have a clue how to load it then...
I need my ultima 7 fix on PSP  ;D (snes version is shit...)
« Last Edit: November 29, 2006, 07:50:13 AM by raskolnikov »
Re: exult
« Reply #1 on: November 29, 2006, 11:54:23 AM »
errr.. what's exult ? care to give us any links etc?
i looked up ultima 7
http://hol.abime.net/230
this says it's AGA, so therefore not possible on PSPUAE :(
Ultima's III - VI  should work ok though
raskolnikov
Re: exult
« Reply #2 on: November 29, 2006, 05:15:35 PM »
exult is an emulator that was ported to amiga...
http://www.muenster.de/~tomjoad/exult.html
i tried to put it on a disk image (ADF) but the file size is too big... is there a way to load it from MS or from virtual hard drive? this is AGA too? impossible?... :'(
*edit*
on original page it says "Notes:      Not an original Amiga release, but playable only through Exult interpreter. The Forge Of Virtue data disk also playable with main game" at the bottom, so I guess this is the same thing...and impossible.  :'(
thanks for your help.
« Last Edit: November 29, 2006, 05:20:31 PM by raskolnikov »
Re: exult
« Reply #3 on: November 29, 2006, 05:35:16 PM »
yeah, i guess you'd need that exult emulator ported to the  PSP tbh...
no hard disk support at the mo on pspuae, and emulation through AGA would be -very- slow on it, even if there was :(
