Author Topic: Help with running old T17 games (superfrog, Worms DC)  (Read 8391 times)
DrBlackJack
« on: January 09, 2007, 08:01:04 PM »
I'm having trouble running these old, great games on my PSP. I'm running 3.03 OE-A, and I'm using the latest version, but the amiga won't boot up when I load the disks.  If possible, could somebody please try them out and post configurations, and perhaps a savestate? Thank you very much. You can get both Superfrog and Worms Director's Cut legally at dream17.co.uk.
Re: Help with running old T17 games (superfrog, Worms DC)
« Reply #1 on: January 09, 2007, 11:04:39 PM »
Any more details?
You get the boot screen? but freezes once you insert an .adf?
If so, you may have set the memory to high. Try the emu defualt settings, and also try deleting Config1 in the configs folder if you have saved 1, as this will override the pspuae default boot options.
What type of images are they? .adz, .adf etc etc.
Do any other games work?
« Reply #2 on: January 10, 2007, 01:25:24 PM »
Worms DC is AGA only
« Reply #3 on: January 10, 2007, 05:27:58 PM »
whoooops, didnt spot that horace, you got my back, ;). Anyways, superfrog should work, but i hear its slow, aint tried it myself.
Mike UK
« Reply #4 on: January 10, 2007, 08:25:17 PM »
Yep superfrog is playable but a bit slow still messing with the settings to see if i can get any improvement though :)
EmuChicken
« Reply #5 on: January 11, 2007, 05:44:21 AM »
how is it without sound?
Mike UK
« Reply #6 on: January 11, 2007, 10:13:16 PM »
Alright well good enough to keep me occupied for almost an hour the other night :D
