Author Topic: NOVICE NEED HELP WITH EMULATORS  (Read 10862 times)
GORDY
« on: January 14, 2007, 05:59:19 PM »
IVE ONLY JUST DISCOVERED ABOUT EMULATORS ON PSP DOWNLOADED DGEN BUT WONT WORK AS I HAVE VERSION 3.02 UPDATE ARE THERE ANY EMULTORS THAT WORK WITH THIS VERSION OR DO I HAVE TO DOWNGRADE AND HOW  EASY IS THIS TO DO. YOUR HELP WILL BE APPRECIATED THANKS
Re: NOVICE NEED HELP WITH EMULATORS
« Reply #1 on: January 14, 2007, 06:21:24 PM »
Well your out of luck, any firmware above 2.80 can not run any homebrew, so until an exploit is found, your screwed, :(.
TIP:- please lay off the caps, ;)
PSPrulez
« Reply #2 on: January 15, 2007, 12:53:13 PM »
You can't downgrade your 3.02. I'm sorry.  :'(
Vince
« Reply #3 on: June 09, 2007, 11:09:31 PM »
If you have 3.02 it's possible to upgrade with 3.03 and after that with the non patched version of GTA PSP you can downgrade to 1.5 ;)
Bye
« Reply #4 on: June 10, 2007, 09:53:05 AM »
Bye
Yeh, now it is, but check the post date, ;). Im sure he knows about the 3.03 downgrader by now. If anyone else has a PSP 2.00+ to 3.03, I advise using the n00bz downgrader, as it patches the IDStorage of newer PSP's fine.
