Author Topic: Putting adf files back onto the Amiga  (Read 14915 times)
Re: Putting adf files back onto the Amiga
« Reply #15 on: February 18, 2007, 10:42:51 AM »
Well I missed out on the A1200 but got a good condition A500 with the 512k expansion.
Comes with RF modulator so I can hook it up to a telly. Joystick, mouse etc etc. Will have to grab a 2nd disk drive which I can get easily enough.
Should be fun.
Shame you missed out on that 1200, :(. This would have come in handy for you, ;).
ADF 2 FLOPPY Tansfer Kit
Could buy a catweasel Mk4, then you could have a floppy connected to it to read Amiga disks on your pc.
« Last Edit: February 18, 2007, 11:16:33 AM by FOL »
knight76
« Reply #16 on: February 18, 2007, 02:06:46 PM »
I am heading down that path at the moment. ie, Buying a catweasel mk4. Have to locate one in australia.
If i am correct that means I will be able to read the amiga disks and also copy my adf files onto this disk to put back into the amiga.
Ill keep my eye out for a 1200 again.
* also discovered a program called Amiga explorer which allows file transfer direct to the floppy of the amiga 500 via null modem cable. This is interesting and something I will try as its all software based. If it can write direct to the floppy this will be awesome.
Anybody tried this and have any feedback?
« Last Edit: February 18, 2007, 02:49:15 PM by knight76 »
