Author Topic: simple PSPUAE Install Guide  (Read 7530 times)
« on: March 22, 2007, 07:51:02 PM »
the KICKs roms it should you have original from the diskettes functional to Amiga. do not ask him from us for that.
that other you want you can ask in this topic
havefun
Re: simple PSPUAE Install Guide
« Reply #1 on: March 22, 2007, 07:59:35 PM »
Thanks Anemos,
Just incase anyone has any problems understanding our greek friend.
You should get your Kickrom from a functional Amiga, so dont ask for them.
If you have any other problems, ask here.
In Anemos's pic, you can see he is using V1.50 Firmware. Obviously with 1.00 and other firmware, you use the single folder method.
« Last Edit: March 22, 2007, 08:01:30 PM by FOL »
« Reply #2 on: March 22, 2007, 08:16:41 PM »
im on PSP FirmWare: V3.10 OE this working alsw on 1.50
« Reply #3 on: March 22, 2007, 08:21:34 PM »
I should have posted thisw before, but with 3.03 OE C, PSPUAE will not work in 3.03 Kernel, but in 3.10 OE it does, so you can use the V1.00 EBOOT.
So you have a choice, you can use either 1.50 or 1.00
