Pages: [1] 2 3   Go Down
Author Topic: PSPUAE Game Compatability Chart  (Read 32684 times)
« on: July 18, 2006, 12:26:57 PM »
I have created a Compatability Chart, that will list the configs for PSPUAE to get adf`s running.
Click add to database, enter all the Details in and it will be added to the list, as so others can search for the config for a perticular game.
To search, just select from the drop down and click search.
Its V0.1, so post your ideas / improvements etc etc.
Re: PSPUAE Game Compatability Chart
« Reply #1 on: July 18, 2006, 06:03:13 PM »
is it possible for us admin to edit entries once they are in?
only i was putting in Bloodwych and put it in straight after finding the ADF name.... there's no settings for it!
« Last Edit: July 18, 2006, 06:16:08 PM by Hungry Horace »
« Reply #2 on: July 18, 2006, 06:17:49 PM »
and the ADF filename field length seems to be too short!
« Reply #3 on: July 18, 2006, 06:18:36 PM »
Trust you, i can add an edit, ;) and increase length
« Reply #4 on: July 18, 2006, 06:20:55 PM »
man you think this is bad???
you should seen what i was like beta-testing pspectrum!!
the author loved / hated me all in one hit as i was so good at breaking his program!
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #5 on: July 18, 2006, 10:29:16 PM »
Maybe you can add a comments box for additional info such as possible settings for the in-game options.  Games such as Indy 500 have 3 different gfx settings which people might not realise and it can help with the frame rate.
« Reply #6 on: July 19, 2006, 11:35:09 AM »
Was busy last night, ill add the suguestions, once my modem is working.
« Reply #7 on: July 19, 2006, 09:05:43 PM »
Got my modem working, stupid cable tv keeps knocking my modem out, :(. Now the server for this site, are being stupid, all there support is down, cant contact them at all, so this will have to wait, yet again. If it were just a case of not being able to access anything, id say fair enough, but I can access my sites fine, just not the FTP or Site control , this sucks, :(
« Reply #8 on: July 21, 2006, 01:15:02 AM »
Changed name, its name PSPUAE Game Compatability DataBase. Anyways, its now complete, just need to improve the admin side. If you make a mistake, it tough, you have to contact an admin to sort it for you.
« Reply #9 on: July 21, 2006, 01:46:39 AM »
remind me not to p*ss about with admin functions after the pub!! i just deleted thw Turrican 2 entry...  ::) sorry!
i'd put it back in but i havent tested it myself...
i thought it was just gonna edit it!!
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #10 on: July 21, 2006, 01:52:59 AM »
LMAO.
super_hoops1967
« Reply #11 on: July 21, 2006, 10:26:34 AM »
i just went to add a game to the compatability list and all it came up with is this
Click here to Return to Search Page
Name  [                          ]
No. Of Disks  [          ]
why's it all gone nuts, it was working yesterday because i managed to add the champ manager italia settings (which have now dissapeared from there).
« Reply #12 on: July 21, 2006, 11:37:56 AM »
Name  [                          ]
No. Of Disks  [          ]
Very odd, im in work atm so I cant check it out, Ill look once I get home.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #13 on: July 21, 2006, 11:56:56 AM »
Works fine for me, do you see a scroll bar so you can scroll down to see the rest of the options?
« Reply #14 on: July 21, 2006, 11:58:56 AM »
Firefox is obviously a supreme browser, as it knew, I had to edit to to add scroll bars for IE6.
Pages: [1] 2 3   Go Up
