Author Topic: 3.03eo-a and PSPUAE 0.62 tryed everything but failed!  (Read 12894 times)
smiljanicn
« on: April 28, 2007, 09:12:18 AM »
Hi everyone, i am a noob in PSP waters but very expirienced Amiga user,
almoust 15 years of using Amiga. I have read and done everything with kickroms,
and all i have is splash screen, then black screen for about 15 sec and then PSP turns off. i don't know what is the problem, maybe my firmware? Please help, i am desparate :(
Re: 3.03eo-a and PSPUAE 0.62 tryed everything but failed!
« Reply #1 on: April 28, 2007, 03:52:29 PM »
It works fine on that firmware, what kickroms are you using? Amiga Forever?
Is your GAME folder, 1.50 or 3.03 Kernel?
Also do you have any config files (options1.pspuae) as this will override the default config, and can cause problems.
« Reply #2 on: April 28, 2007, 05:23:58 PM »
what PSP firmware you have ?
« Reply #3 on: April 28, 2007, 05:28:51 PM »
Anemos, hes on 3.03 OE-A, its in the title, ;)
« Reply #4 on: April 28, 2007, 09:35:45 PM »
oh..i dont see  ::)
maby the problem is kickroms yes..and the rightly Directorys.
smiljanicn
« Reply #5 on: April 29, 2007, 03:10:56 AM »
Finaly i got it to work. IT WAS BLOODY KICKROM, my brother dumped one from our amiga 500! IT IS WORKING FINE!!!
Thank you for replies,
« Reply #6 on: April 29, 2007, 01:16:50 PM »
Glad you got it sorted,  ;D
The Evolution Of Life
« Reply #7 on: October 05, 2007, 11:56:44 AM »
Glad you got it sorted, this was my experience with the AMIGA Forever Kick's, which is on topic, although you sorted your problem, for those who have the same problem as you did, in the past, currently.
The AMIGA Forever Kickrom's work for me on 0.63. You have to go into the Normal non overdumped versions folder, then you rename them to the correct names, then copy them to your PSPUAE KICK folder.
So AMIGA Forever Kickstart's isn't a legit problem I think. As long as you use the normal versions.
3.90M33 PSP Phat
0.63 PSPUAE
1GB Pro Duo Memory Stick
No Loaders Just CFW
« Reply #8 on: October 05, 2007, 02:34:49 PM »
Ah didnt know they had non oversized kicks with it. Thanks for that, ill add it to next readme, ;).
« Reply #9 on: October 05, 2007, 02:47:10 PM »
The correct ones are the ones wouhout the weird names, you could tell what they are.
3.90M33 PSP Phat
0.63 PSPUAE
No Loaders Just CFW
« Reply #10 on: October 05, 2007, 03:48:40 PM »
Can you post the names as they appear?
« Reply #11 on: October 06, 2007, 09:57:53 AM »
E-Boot Name - System - Year "No Weird Names in between, or it's fake"
I can't read my kickroms names from the disk at the moment because my CD-RW has broken down.
But I think those were how the names were like.
Must all be the same filesize as the ones noted in the FAQ too to work.
« Last Edit: October 06, 2007, 09:59:37 AM by The Evolution Of Life »
3.90M33 PSP Phat
0.63 PSPUAE
No Loaders Just CFW
