Author Topic: How do I rip files from my old Amiga disks?  (Read 20692 times)
0 Members and 7 Guests are viewing this topic.
ParaSitius
  • Swish
    • ParaSitius.com
« on: July 18, 2006, 06:41:25 PM »
Still got all my original games boxed and waiting to be played, of course the problem is that I can't use them while they sit on floppy disks.
So basically, what do I need to get them onto my PC so I can then transfer them onto my PSP?
Any help would be appreciated.
Dementia13
  • PSPUAE Moderator
Re: How do I rip files from my old Amiga disks?
« Reply #1 on: July 18, 2006, 07:34:44 PM »
Well what you need is some special programs or something (I´m not realy sure)
Check this site... might give you some clues... http://www.amigaforever.com/kb/3-118.html
...but the easiest way is of course to simply search for ADF-files (Amiga Disk Files) on the net.
(Of course... anything personaly done can´t be "saved" by this way)
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #2 on: July 18, 2006, 08:01:45 PM »
Thanks for the info.
« Reply #3 on: July 18, 2006, 08:07:19 PM »
there's not much point in ADFing original disks, since nything with a copy protection simply wont work.
my favourite ADF site is down at the moment, but i'd recommend downloding the entire ADF TOSEC off bittorrent or E-Donkey, since this way you'll more than likely find every game you ever want!
unless of courseyou happen to have "Horace Takes A Trip" (PD Game) .... in which case, it needs ADFing!
« Reply #4 on: July 18, 2006, 08:11:50 PM »
Lmao, you Hungry Horace mad, im more of a *ouch my fingers hurt* Dailey thompsons decathlon man, ;). Icant ADF my originals, cause when to get them from my mothers attic, only to find somone had stolen it all from the attic, via another attic (you could run through the whole block of houses through the attics), I was gutted, I lost SHUTTLE, that game was 1 of myfavorites and Willy Biemish.
« Reply #5 on: July 18, 2006, 09:59:45 PM »
of course i'm Horace mad!!
i still have an AMOS game to finish coding.... Horace Boxing! (when i find the time)
online multiplayer madness!!! with Horace, Boris, Maurice and Norris!!!
« Last Edit: July 18, 2006, 10:01:21 PM by Hungry Horace »
« Reply #6 on: July 18, 2006, 10:00:57 PM »
i still have an AMOS game to finish.... Horace Boxing!
LMFAO, nice 1, I like the names, ROFLMFAO
HORACE BOXING, I like it.
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #7 on: July 18, 2006, 10:37:56 PM »
LOL, superb.
Horace Goes Skiing was actually the second game I ever played on my Speccy 48k way back in antiquity.
« Reply #8 on: July 18, 2006, 11:19:36 PM »
i want to finish the rick dangerous.. ;D
the game play at full speed  fame skip/1  sound -stereo
 :o :o :o
bwlfp
« Reply #9 on: July 24, 2006, 05:18:36 PM »
Yowzers I have just tried to download the adf tosec file off Overnet and BitTorrent and it is 3.8 Gigs.  There are other ones around the 300-400 meg mark.  However nothing is happening and I fear it will never download.  Is there any recommended way of getting hold of this archive of games.  If anyone knows how I can get hold of Captive (captive.adf) listed as a compatible game on PSP I would really be grateful.  My first post, great site!
« Reply #10 on: July 24, 2006, 06:16:12 PM »
i'd really recommend waiting, and getting all 4.5  gigs worth.... (that how big mine was!) but you should be able to find them in packs labelled by letter... "A" "B-C" "D-E" etc etc which will be a bit smaller.... at least on overnet anyway. Bittorrent will be better for speed however. I only had a 512k connection when i downloaded them all, but it was worth the wait!
planetemu.net had the contents of the TOSEC up for download as individual games, but at the moment they are moving host i think, so downloads arent working. i'll see if i can dig out captive at some point (it's not on my PC)
bwlfp
« Reply #11 on: July 24, 2006, 09:45:50 PM »
Thank you, I will continue to try and download the TOSEC file.  For Captive FOL has shown me the way to the adf file and I currently have it running on the PSP and am currently trying to work out a control scheme that makes it playable.
« Reply #12 on: July 24, 2006, 09:54:05 PM »
lol, been waiting for your reply, ;).
« Reply #13 on: July 25, 2006, 08:52:24 PM »
www.planetemu.net
where you can download the whole TOSEC as individual game zips, is now back online and working!
enjoy.
« Last Edit: July 25, 2006, 09:30:32 PM by Hungry Horace »
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #14 on: July 25, 2006, 08:57:13 PM »
Site looks down to me.
