Author Topic: arg - sound probs  (Read 7559 times)
f4c3
arg - sound probs
« on: June 17, 2007, 09:10:06 PM »
hi folks - first sry 4 my bad english :)
ok now my problem - i installed psp uae with my kick 1.3 and now i want 2 play some good old games :) - but i have same problems in all games the sound is scratching and lopped off :( and the cpu is between 110 and 200 :( i tried several methodes but without success
 noises
4 example: when i load oil imperium and than the intro starts the music runs fast - slow and with bad noises
now i have config -
cpu 68020
speed chipset - 100%
blitter... off
immediate... off
collision playfields
chipset: ecs_agnus
soundemu:
normal
stereo
none
rammenu
1024
1024
512
kick: 1.3
psp - diplay  - only change 4:3
when i trie to play with cpu max option - than i have bad sound and many frameskips
i tested - north and south - turrican 2 - oil imperium - wings of death - in every game had same sound probs or many many frameskips
ps: my psp cpu is on 333mhz and i have 3.40oe
please help me - wanna play all of my old games :(((
Re: arg - sound probs
« Reply #1 on: June 17, 2007, 09:20:53 PM »
 noises
now i have config -
cpu 68020
blitter... off
immediate... off
chipset: ecs_agnus
soundemu:
normal
stereo
none
rammenu
1024
1024
512
kick: 1.3
Sound is an issue, but its not that bad. Turrican 2 and North & South play quite well, not sure on other 2. Have you tried the savestate of Turrican 2 in the downloads section?
In the current release, chipset 100% does have a nasty side effect and can cause slow down if lots of data on the screen, sometimes its best to have Auto frameskip on.
The only difference I can see is you are forcing CPU to 333Mhz, have you tried setting it to default, as PSPUAE tells PSP to run at 333Mhz.
I dont see the point in the CPU speed option in the recovery menu, i have never used it once and never needed to.
f4c3
« Reply #2 on: June 17, 2007, 09:39:33 PM »
thx 4 fast answering
setting cpu speed to default has no effect
cant load the savestate cause i only have kick 1.3  but for savestates he ask me for kick 3.0
i tried chipsetspeed max - than the sound is alilbit better but than i have frameskips - maybe the sound is better with the next version - btw - is there a releasedate???
« Reply #3 on: June 17, 2007, 10:10:25 PM »
All I can say is soon, its still being worked on.
