Author Topic: Savestate downloads down?  (Read 9751 times)
digiteam
« on: June 21, 2007, 09:26:29 PM »
Hi guys,
sorry to do such a first post, but I was not able to download savestates (neither with firefox nor with internet explorer or download manager). The .zip files have always 0kb
Keep up the good work! Waiting for 0.63!
Greets from Switzerland
Re: Savestate downloads down?
« Reply #1 on: June 21, 2007, 09:46:10 PM »
Hi guys,
Hi, downloads are fine, just downloaded 4, all downloaded and extracted fine. Must be your end, or your ISP
digiteam
« Reply #2 on: June 22, 2007, 06:17:22 PM »
Thanks for checking, I still have the same problem... I will try at work next week!
« Reply #3 on: June 22, 2007, 07:21:39 PM »
You got wifi? if so, try downloading from www.pspuae.com on your PSP (You will get this site if you try it on anything other than a PSP).
I setup a PSP version of site, although outdated, it is another way to confirm if its your Computer or ISP.
« Reply #4 on: June 22, 2007, 07:49:26 PM »
when are we going to be able to get on the forum via the PSP?
still get annoyed at that :p
« Reply #5 on: June 22, 2007, 08:11:54 PM »
When I get chance to work on it. It still might not be possable due to the sql encryption.
« Reply #6 on: June 22, 2007, 08:40:00 PM »
could you not just have the normal page on www.pspuae.com and the psp special page on like.. psp.pspuae.com or someat? hopefully avoid those sort of coding problems?
or a special forum.pspuae.com access?
just thinking out loud here!
« Reply #7 on: June 22, 2007, 08:42:17 PM »
Like I said, when I get chance to work on it, ;)
