Author Topic: Savestates where are they?  (Read 8799 times)
kinkladze10
« on: June 22, 2007, 11:10:21 PM »
Hi guys Im loving the site and everything here, but where are the savestates to be found?
I can't see them anywhere?
thx
Re: Savestates where are they?
« Reply #1 on: June 22, 2007, 11:38:45 PM »
thx
LMFAO, ;).
DOWNLOADS section is where they are.
baboon
  • Amiga fanatic
  • Moon Monkey
« Reply #2 on: June 23, 2007, 12:07:03 PM »
Just make sure your logged in or else you wont be able to view the savestates.  ;D
« Reply #3 on: June 23, 2007, 12:14:34 PM »
Indeed, but you have to be logged in to post, ;). Plus I have stated, as has Horace, you have to be registered to see them and download them.
So, in order to download the SaveStates, your will need the following;-
1) Be a registered user (Only SaveStates require Registration)
2) Be logged in (Guests / Non users will not see the States in downloads section)
This has all been mentioned before, even in the news section, if i remember correctly.
« Last Edit: June 23, 2007, 12:23:27 PM by FOL »
kinkladze10
« Reply #4 on: June 23, 2007, 05:36:09 PM »
omg I'm such a noob, I wasn't logged in sorry about that, now I see them doh  ::)
« Reply #5 on: June 23, 2007, 05:38:34 PM »
lol, no problems,  ::).
We also take requests for states, if you want any.
kinkladze10
« Reply #6 on: June 24, 2007, 11:28:59 AM »
hmmm ok then I'll take you up on that.
I'm a big fan of the dungeon crawler games Bloodwych, Captive, DM etc
I'm also into the Champions of Krynn and Death Knights of Krynn too.
One of my problems is getting Champions to run at a steady pace, I have the 3 disks and I've made a save disk so I can save my game, there is probably an easier way to do that I reckon with the save states but I'm a noob so wouldn't really know.
My main problem for Bloodwych, DM etc is that I can play them and I have mapped the movement keys to the directional pad using the up, down, left and right arrows but the problem is I can't get the diagonal right and diagonal left buttons to work, the sidestepp buttons are pretty useless so I can I map diagonal right and diagonal left?
thx in advance
« Reply #7 on: June 24, 2007, 11:51:16 AM »
thx in advance
Ill take a look at champions, for the bloodwych and DM, horace is the best person for this as he loves those games to. If you do a search on youtube for PSPUAE, you can see horaces vids of him playing bloodwych with ease.
kinkladze10
« Reply #8 on: June 24, 2007, 03:17:48 PM »
Nice one will do
« Reply #9 on: June 24, 2007, 03:35:58 PM »
Nice one will do
Right, champions of krynn added to downloads section. I also set the controls up as BuckRogers (dont know why, but I only like BuckRogers in this type of game genre), as it uses the same game engine.
kinkladze10
« Reply #10 on: June 26, 2007, 10:50:29 AM »
Cool, nice one thx m8 :)
« Reply #11 on: June 26, 2007, 11:15:11 AM »
kinkladze10 - the trick is to map your left/right rotate keys the shoulder buttons - in the case of Bloodwych, (one of the greatest games ever btw) these are del/help, though a lot of other dungeon-crawler games use the numpad for movement, and so probably use "7" and "9" on that to rotate - i know EOTB does.
FOL is right, my youtube videos do show this being done to great effect :)
ill try and get a decent Bloodwych state up soon, which will include both game & data disk, and a nice tidy control system for menu naviagtion (L+dpad for F-keys etc) - although i must admit, i simply used an ADF of the cracked copy when i played through originally, (using savestates along the way) howver, this did make transferring my game to the data disk somewhat cumbersome, as the data disk has to use an especially formatted custom ADF for the save-game transfer, which often crashes winuae when you try to get it ready, and there is no proper crack of the data disk either (i used an ADF which contained the game save-stated on my original a500 with the action-replay cartridge)
at absolute minimum, i'll upload the 3 adfs i used for this for you (game, datadisk & savedisk) - although my integrated savestate would still be the better option!
EDIT - SaveState for Bloodwych now in Downloads Section
« Last Edit: June 28, 2007, 11:07:00 PM by Hungry Horace »
