Author Topic: GTA downgrade on 2.82  (Read 5740 times)
flynny1st
« on: June 27, 2007, 10:30:27 PM »
Hi as a noob i want to ask about this before i go breaking my psp. i read about the GTA exploit downgrader. i#m running 2.82 on my psp can anyone tell me whether this will downgrade my psp? if so is it easy to do?
thanks matt.
monti
Re: GTA downgrade on 2.82
« Reply #1 on: June 28, 2007, 01:35:46 PM »
If you have the original versjon of GTA Liberty City Stories, it should be fairly easy.  You need to upgrade to fw 3.03 first -- see http://www.psp-hacks.com/forums/viewtopic.php?id=17935
You can also downgrade with Lumines, if you have that.  You need to upgrade to fw 3.50 first if you do -- see http://www.psp-hacks.com/2007/06/26/psp-350-firmware-downgrader/
