Author Topic: PSPUAE doesn't like my ADF files.....  (Read 11924 times)
booyah171
« on: July 13, 2007, 04:03:34 PM »
These are non-zipped, fully working ADF files that work fine in the PC emulator but it will not let me select them in PSPUAE. When I select certain files, it acts as if I didn't select anything.
I've tried renaming the files to the 8.3 rule and still nothing.
Re: PSPUAE doesn't like my ADF files.....
« Reply #1 on: July 13, 2007, 04:07:08 PM »
youll have to post them up, or show us where we can download them to test tbh mate.
they arent HighDens disks, but DoubleDens selected or anything are they? custom adfs etc?
(though i've never had any problems with custom adfs either)
i am curious to know how you mean about "wont select" ?
what psp firmware, version of pspuae etc you running... any details may help.
« Last Edit: July 13, 2007, 04:46:26 PM by Hungry Horace »
booyah171
« Reply #2 on: July 13, 2007, 09:24:36 PM »
I have kick13.rom installed, PSP firmware of 3.03C
These roms work fine on the PC emulator.
When I select a disk for the drive it takes me back to the menu selector as if I didn't select any roms.
« Reply #3 on: July 13, 2007, 09:45:41 PM »
You press O or X when you select adf?
« Reply #4 on: July 13, 2007, 10:32:24 PM »
err.. you are not trying to load kick13.rom in the floppy drive are you? hehe
(i think its just the way you've written it!)
select  kickstart1.3 - reset amiga - insert adf with X  - this is the most you should need to to tbh.
i assume you see the kick1.3 boot screen when you boot pspuae?
booyah171
« Reply #5 on: July 13, 2007, 10:43:43 PM »
Yes, and of the 10 ADF images I have only one works (BMX simulation) so it *is* working with certain files but not the majority of them.
« Reply #6 on: July 13, 2007, 10:47:38 PM »
k, well from what you said it has to be your adf's. I havent had any adf's not work, where did you get them?
retiari
« Reply #7 on: August 14, 2007, 05:33:05 AM »
The Problem is ,you must uncheck the writeprotect checkbox on the adf files,with options ,on windows explorer :)
« Reply #8 on: August 14, 2007, 09:37:34 AM »
Hmmm, never had to do this. Can you supply the adf's that require this, so i can confirm, as all the adf's i have tried (100+) have worked fine, no problem.
« Reply #9 on: August 14, 2007, 05:14:17 PM »
i managed to create one of these non-working adfs when making a RISS once (i meant to post it :S)  i am wondering if i accidently write-protected in winuae though?  might be the cause? unlikely but hey... work a check
retiari
« Reply #10 on: August 14, 2007, 09:09:39 PM »
yes its a special problem but its real .You can test it.Download the files from http://www.amigaland.de at my pspuae 0.63 was the problem at bloodnet aga (file 1 - 4 was writeprotected) and at Ufo EU was all files writeprotected.And writeprotected Files won,t work in drives.Sorry my bad english, hope you understand me ;).
