Pages: 1 [2] 3 4 ... 6   Go Down
Author Topic: PSPUAE V0.63 (Birthday Edition) RELEASED  (Read 75320 times)
ParaSitius
  • Swish
    • ParaSitius.com
Re: PSPUAE V0.63 (Birthday Edition) RELEASED
« Reply #15 on: July 15, 2007, 12:52:25 PM »
Ah, nicely done chaps.
Glad to see that things are chugging along at a nice pace and each release is better then the last.
Keep up the good work.
« Reply #16 on: July 15, 2007, 12:58:34 PM »
Hey, ParaSitius, where you been hiding. Aint seen you for awhile.
« Reply #17 on: July 15, 2007, 01:31:01 PM »
Big thanks to the team and its dedicated followers for all the work they have done, especially FOL, Horace, Gnostic and CMF for the time and effort that they have put in these last couple of months.  I might send all of you a big pack of caffeine tablets as a thank you ;D
« Last Edit: July 15, 2007, 05:23:19 PM by skateblind »
Trekster
  • tis a far far better thing I do....
    • Digital Dreams Classic Gaming
« Reply #18 on: July 15, 2007, 05:02:44 PM »
Thank you for the new release. I think it's great that there is support for the mighty Amiga. I hope that it is possible to more accurately emulate sound, more specifically music in games as that was a large part of Amiga gaming for me. I am playing Lemmings (CDTV savestate)  the sound appears to be much clearer than the music, hopefully int he future the 2 will be seamless. Fingers crossed.
delta191
« Reply #19 on: July 15, 2007, 05:51:32 PM »
 ;D oh yes, what a grand bunch you fellas are, I checked on QJnet and your new release was spotted, I love this brilliant emulator and was waiting for an update, I downloaded it along with the new 3.51FW by the russians! slapped on alien syndrome at 2 frame skip and away we go, it's not perfect, but its smoother and the sound isn't as scratchy as with 0.62CE.
Thanx guys, I really appreciate this release and thanks for your effort, we all should praise you for giving us retro game play on our psp's.
I want to try all the games now, thanks to you all!!!!! :D
« Last Edit: July 15, 2007, 05:53:33 PM by delta191 »
monti
« Reply #20 on: July 15, 2007, 06:28:52 PM »
Congratulations, great work guys!
ParaSitius
  • Swish
    • ParaSitius.com
« Reply #21 on: July 15, 2007, 06:35:10 PM »
Life, the universe and everything has been taking up my time so I don't get much time to surf the internettyweb as much as I used too.  I've not even been able to use my PSP for several months now, poor ickle me.
« Reply #22 on: July 15, 2007, 06:40:55 PM »
Whats happened to your PSP? :'(
« Reply #23 on: July 15, 2007, 07:09:24 PM »
Im guessing nothing, just hes to busy to do anything like that as he said.
If there's anything you need ParaSitius, give me a PM
Seal
« Reply #24 on: July 15, 2007, 07:38:20 PM »
Very good work, guys!
Emulation is better and better ...  :o
I like amiga music/sound. Will be possible to make some mode to emulate music to be nearly perfect with high sampling resolution of sound and slow game playing performance?. For example to listen music in games like Turrican or mods from trackers?
Amiga Fan from Czech Republic
« Reply #25 on: July 15, 2007, 07:45:13 PM »
Best, to use milkyplayer for PSP, thats what i use to listen to .mod files on my PSP.
delta191
« Reply #26 on: July 18, 2007, 11:26:32 PM »
this is really promising!
I couldn't get XENON running very well (although XENON II ran great) on PSPUAE V0.62CE, lots of testing, frameskipping ect... but still rather dissapointing.
now after half an hour fiddling and testing, Ive got XENON running great! fast and smooth and the sounds much better - this 0.63 is brilliant fellas! hats off to you!
also tested so far with excellent results:
Xenon - very good 8/10
Goldrunner - very good. 7.5/10
Airball - almost perfect. 9/10
Backlash - perfect 9.5/10
Barbarian(palace) - good 7/10 (I cant get full screen) but works and sounds great.
Black Tiger - almost perfect 9/10
f29 Retaliator - this was a bitch! it takes ages to load, but now i have a savestate! runs really good and sound is excellent. 8.5/10
Golden Axe - runs  well, tad scratchy, slows down when lots of sprites. 7/10.
good results! cheers guys. ;)
porthose
« Reply #27 on: July 19, 2007, 08:38:02 AM »
Hello everyone, first post.
Thank you very much for PSPUAE -amazing work.  Though I don't code (I work as a unprofessional test analyst) I can understand the immense amount of work that's gone into this.
Just wondering if delta191 could upload the save state for f29.  I have the original box and packaging (yellowing with age!) and would be great to have this on a handheld.
thank you.
« Reply #28 on: July 19, 2007, 06:46:05 PM »
thank you.
If the state is whdload registered only, then you need the whdload key in order to play. If you ment the ADF, check your PM's, ;)
« Reply #29 on: July 19, 2007, 07:15:43 PM »
i see nothing about it requiring registartion:
http://www.whdload.de/games/F29Retaliator.html
no one has yet made a RISS for it though
Pages: 1 [2] 3 4 ... 6   Go Up
