Author Topic: PSPUAE 0.63 README (REVISED 15-7-07)  (Read 9571 times)
« on: July 15, 2007, 03:04:34 PM »
Below is the revised readme that includes "Options and What They Are". It should have made the release, but didnt.
PSPUAE V0.63 (Birthday Edition)
It has been given the name BE, due to it being exactly 1 year since pspuae.com started.
README V2.6
Homepage = http://www.pspuae.com
PSPUAE GUI Graphics by Hungry Horace
Thanks to all the site staff and BetaTesters at pspuae.com
Thanks to the PSPUAE DEV TEAM
README Updated by FOL.
Instructions Installation
*Now compatable with all (Homebrew capable) PSP`s*
Unzip PSPUAE 0.63.
inside the zip you will find 2 folders called V1.00 and V1.50.
Open the V1.50 folder.
Open the PSP folder, Open the GAME folder.
Drag and Drop %__SCE__PSPUAE & __SCE__PSPUAE to the GAME folder of your
MS (normally ms0:PSP\GAME\), See below (typical dir structure).
MS0:(MemoryStick ROOT DIR)
|-PSP\
  |-GAME\
It may prompt you to Overwrite, click "yes to all".
V1.00 / Custom Firmware Install.
Open the V1.00 folder.
Drag and Drop the PSPUAE folder to your MS (normally ms0:PSP\GAME\),
|-PSP\
  |-GAME\
With Custom Firmwares, you may also use the old V1.50 KXPLOITED EBOOT,
Drag and Drop %__SCE__PSPUAE and __SCE__PSPUAE to the GAME150 folder of your
MS (normally ms0:PSP\GAME150\), See below.
|-PSP\
  |-GAME150\
Although V1.00 EBOOT is a FW V1.00 EBOOT, it is untested on PSP FW V1.00, but
it should work.
**WARNING**
You will also need to have a VALID Amiga ROM dump file,
you will have to find this yourself.
*NOTE:- If you do not have a Kick.ROM / Working Kick.ROM,
then PSPUAE will Display a message, stating the KickRom is missing and will then return
to the PSP XMB Menu.
If you change to another KickRom while using PSPUAE and its missing,
it will display a message and then continue to use Kick13.rom.
They should be named as follows:-
KickStart 1.0 = kick10.rom (A1000)
KickStart 1.1 = kick11.rom (A1000)
KickStart 1.2 = kick12.rom (A500 - A1000)
KickStart 1.3 = kick13.rom (A500 - A1000 - A2000 - CDTV)
KickStart 2.0 = kick20.rom (A3000)
KickStart 2.04 = kick204.rom (A500+ - A3000)
KickStart 2.05 = kick205.rom (A600HD)
KickStart 3.0 = kick30.rom (A1200 - A4000)
KickStart 3.1 = kick31.rom (A1200 - A4000 - CD32)
These should be placed in the following folder:-
1.50
|-PSP\
  |-GAME\
    |-__SCE__PSPUAE\
      |-KICKS\
|-PSP\
  |-GAME\
    |-PSPUAE\
      |-KICKS\
Custom Firmware (Using V1.50 KXPLOITED EBOOT)
|-PSP\
  |-GAME150\
    |-__SCE__PSPUAE\
      |-KICKS\
Games
Games for the Amiga Emulator, come in a few formats,
the most popular being .ADF (Amiga Disk Format). These .ADF files must
1.50
|-PSP\
  |-GAME\
    |-__SCE__PSPUAE\
      |-DISKS\
|-PSP\
  |-GAME\
    |-PSPUAE\
      |-DISKS\
|-PSP\
  |-GAME150\
    |-__SCE__PSPUAE\
      |-DISKS\
PSPUAE also accepts .zip files, so if you insert (Example: Turrican.zip) then it will
work as if it were Turrican.adf.
Save States
You can Save / Load upto 5 SaveStates, or You can rename the states to what the
Game / Application is (i.e. Lotus.asf) It will then show in the Load State MENU.
You can also save the state with the name of the .adf in DF0:.
Save states can be found in the following folder:-
1.50
|-PSP\
  |-GAME\
    |-__SCE__PSPUAE\
      |-STATE\
|-PSP\
  |-GAME\
    |-PSPUAE\
      |-STATE\
|-PSP\
  |-GAME150\
    |-__SCE__PSPUAE\
      |-STATE\
CONFIGS
You can Save / Load upto 5 options, or You can rename the option files to what the
Amiga Hardware is (i.e. A1200.options) It will then show in the Load Options MENU.
As with states, it will also save as the name of the .adf in DF0:.
Options can be found in the following folder:-
|-PSP\
  |-GAME\
    |-__SCE__PSPUAE\  OR  |-PSPAUE\ (For V1.00 / Custom Firmware)
      |-CONFIGS\
GUI
This is the new home for the MENU BackDrop, (if you need more Fast Ram, then either
remove or rename the menu.png, i.e. menuold.png) or simply turn OFF pic in menu.
BackDrop Pics can be found in the following folder:-
|-PSP\
  |-GAME\
      |-GUI\
ScreenShots
This is the new home for the ScreenShots files. Now everytime a screenshot
it will be saved to a folder
Screenshots can be found in the following folder:-
|-PSP\
  |-GAME\
      |-SCREENSHOTS\
Instructions Usage
Navigate to your GAME folder from the PSPsystem MENU.
Now select and press X on PSPUAE 0.63.
It will now boot the kick13.rom by default.
Press select to bring up the option menu.
Once in the options menu select option from the menu and then press X.
Here you can tweak the config of the Emulator
(remember though there is no AGA), set the options up as you want,
then scroll down and press X on "configurations" and either save as diskname in drive or
select "SAVE OPTIONS #1 - 5". You can also select preset Amiga setups, from the
configurations menu.
*NOTE :- Amiga = All Amiga config options (including Sound)
         PSP   = All PSP related options
Go back to root menu, then select and press X on "drives", now select the drive of your
choice "Insert in DF0: ()" or "Insert in DF1:()", select a game from the .adf list and
press X (if you want to remove a disk, select and press X on "empty").
Once all floppys are inserted, return to root menu.
All that is left is to select and press X on "RESET AMIGA".
**NOTE :- you will have to play around with the config options
to suit your needs. Best to test with no floppies to start, see if it
boots to the ROM screen first.
*NOTE :- If you want to swap X & O (while using menu), you can swap in the Misc Menu.
PSP KEY Controls Default (In Emulation)
TOP LEFT TRIGGER = LEFT MOUSE BUTTON
TOP RIGHT TRIGGER = RIGHT MOUSE BUTTON
D-PAD = JOYSTICK0
ANALOG PAD = MOUSE
SQUARE = ACTIVATE KEYBOARD
CROSS = JOYSTICK0 FIRE
CIRCLE = RIGHT MOUSE BUTTON
TRIANGLE = HI-RES MOUSE MOVEMENT (Lets you move mouse more precise)
HOME = EXIT to PSP XMB
SELECT = OPTIONS MENU (Tweak Settings)
START = SCREENSHOT (Takes a screenshot)
PSP KEY Controls Default (In Emulation (Quick Config Keys))
L+R+DPAD UP  / L+R+DPAD Down      = Zoom  In / Out
L+R+DPAD Left / L+R+DPAD Right    = frameskip  Down / Up
L+R+ANALOGUE STICK                = Move Screen
L+R+TRIANGLE          = CPU Speed
L+R+CIRCLE         = On Screen LEDS
L+R+SQUARE         = Floppy Drive Speed
L+R+CROSS         = MouseStates Menu
L+R+SELECT          = Auto Zoom On/Off (If Off, then its Screen Lock On/Off)
PSP KEY Controls Default (In Menu)
TOP LEFT TRIGGER = SCROLL UP FAST
TOP RIGHT TRIGGER = SCROLL DOWN FAST
D-PAD = SELECT OPTIONS / CHANGE SETTINGS
CROSS = CHANGE SETTINGS
CIRCLE = GO BACK 1 MENU / EXIT MENU (IF IN ROOT MENU)
SELECT = EXIT OPTIONS MENU
PSP KEY Controls Default (In Keyboard)
D-PAD = HIGHLIGHT KEYBOARD KEYS
Triangle = Move Keyboard (Top or Bottom)
SQUARE = DE-ACTIVATE KEYBOARD
CROSS = SELECTS HIGHLIGHTED KEY
CIRCLE = ENTER / RETURN KEY (SAVES YOU HAVING TO MOVE AND HIGHLIGHT ENTER / RETURN)
PSP KEY Controls Default (In MouseState Menu)
D-PAD = HIGHLIGHT REQUIRED STATE
Triangle = DELETE CHARACTERS (While Keyboard Active)
SQUARE = ACTIVATE & DE-ACTIVATE KEYBOARD
CROSS = SELECTS HIGHLIGHTED MOUSESTATE & Keyboard KEY (When Keyboard Active)
CIRCLE = EXIT MOUSESTATES (When Keyboard not Active)
TOP MENU
|-States = SaveState Options
| |-Load State = Lets you load your Saved State (By name or 1 of 5 Slots)
| |-Load State By Name of state or 1 to 5 (in state folder)
| |-Save State = Lets you save your Saved State (By name or 1 of 5 Slots)
| |-Save State By Name of Floppy in drive / state or 1 to 5 (in state folder)
|-Drives = Menu for floppy Drives
| |-Insert In DF0: () = .ADF Dir on MS (lets you choose .adf`s / Zip`s from DISKS folder)
| |-Insert In DF1: () = .ADF Dir on MS (lets you choose .adf`s / Zip`s from DISKS folder)
|-Amiga = All Amiga related Hardware Options
| |-CPU
|   |-CPU Type = What type of Amiga CPU to Emulate
|     |-68000 = A500, A500+, A600, A1000, A1500, A2000, CDTV
|     |-68010 = A500+, A600
|     |-68020 = A1200, CD32
|     |-68030/68881 = A2500, A3000, A3000T, A3000UX, A4000
|     |-68040 = A4000, A4000T
|   |-CPU Speed = How fast to run the Emulated CPU
|     |-Max = Run CPU Emulation as fast as possable
|     |-Real = Runs CPU as if it were an Amiga
|     |-Chipset = Amount of time to share between CPU & CHIPSET (0% Chipset to 100% Chipset)
|                 This option, although gives speed increase. It can also slow GFX on screen
|-Chipset = All Amiga Chipset related Options
| |-Blitter Cycle Exact = Runs GPU as if it were an Amiga (Helps with compatability)
| |-Immediate blits = Runs GPU as fast as possable (Helps with compatability)
| |-Collision Mode = Screen sprite detection level
|   |-None = No detection will take place (Nearly everything will work with this set to None)
|   |-Sprites = Only Sprites are detected (Foreground, I believe)
|   |-Playfields = Only Background Sprites are detected
|   |-Full = Both Foreground and Background Sprites are detected
| |-Chipset = What Custom Chipset to use
|   |-OCS = A500, A1000, A1500, A2000, A2500, CDTV
|   |-ECS AGNUS = A500+, A600, A3000, A3000T, A3000UX
|   |-ECS DENISE = A500+, A600, A3000, A3000T, A3000UX
|   |-ECS FULL = A500+, A600, A3000, A3000T, A3000UX
| |-Sound Emulation
|   |-Sound Emulation = Sound Emulation type menu
|     |-None = No Sound Emulation
|     |-Intterupts = Sound Interrupts are emulated (This is needed for some floppies)
|     |-Normal = Emulated Sound
|     |-Exact = Sound is Emulated 100%
|   |-Stereo = Way sound is output
|     |-Mono = Sound is output in mono
|     |-Stereo = Sound is output in Stereo
|     |-4 CH = Sound is output in 4 Channels, like the real Amiga
|     |-Mixed = Sound is output with all channels mixed
|-RAM = How much memory to emulate in PSPUAE
|   Memory On PSP FW 1.50
|   |-FastMem = Expanded Memory (Max 8192kb)
|   |-Chipmem = Graphics Memory (Max 2048kb) (Mem can be different, but must = 10.5 Megs Total)
|   |-Bogomem = Slow Memory (Max 1536kb)
|     Total = 10.5 Megs
|   Memory On PSP FW 1.00 / Custom Firmwares
|   |-FastMem = Expanded Memory (Max 2560kb)
|     Total = 10.5 Megs
|-Kickstart = Amiga Kickrom (BIOS) selection menu
| |-1.0 = A1000
| |-1.1 = A1000
| |-1.2 = A500, A1000, A2000
| |-1.3 = A500, A1000, A1500, A2000, A2500
| |-2.0 = A2000, A3000
| |-2.04 = A500+, A2000, A3000, A3000T, A3000UX
| |-2.05 = A600, A600HD
| |-3.0 = A1200, A4000
| |-3.1 = A1200, A4000T
| |-Drives Config = How you want to setup the Floppy Drives
|   |-Floppy Speed = Normal (Speed of real Amiga) or Turbo (Double the speed)
|   |-DF0: Drive Type = Double Density or High Density (HD can cause crashes)
|   |-DF1: Drive Type = Double Density or High Density (HD can cause crashes)
|-PSP = All PSP related Options
| |-Display = All display settings
|   |-Direct VRAM Access = Accesses the PSP memory Direct (Can make small improvements)
|   |-FrameSkip = How many frames to skip in every render of screen (i.e. 0 = Every Frame rendered)
|     |- auto or 0 to 8 (0 removed from AUTO FS, as its not needed at the moment)
|   |-Zoom = Zoom function to help fill the PSP screen (some things can go off the screen)
|     |- 0%, 10%, 11%, 12%, 14%, 17%, 20%, 25%, 34%, 100%
|   |-Aspect Ratio = What aspect you want, either 4:3 (Square) or 16:9 (Regtangle / Widescreen)
|   |-Auto Zoom = It looks at the Amiga data (start / stop) that tell the sceen where to draw
|                 With this option "ON" Screen Lock is disabled
|   |-Screen Lock = If in 4:3 Zoom, you can move the screen position, with L + R Trigger
|                   + Analogue Stick, once moved you can lock it with this option
| |-Input Devices = User control setup
|   |-Controls = Main Peripheral Options menu
|     |-Analog Stick = map a keyboard button or input device to the psp`s analogue stick
|     |-Direction Buttons = map a keyboard button or input device to the psp`s joypad
|     |-Start = map a keyboard button or input device to the psp`s start button
|     |-Square = map a keyboard button or input device to the psp`s [] button
|     |-Triangle = map a keyboard button or input device to the psp`s /\ button
|     |-Cross = map a keyboard button or input device to the psp`s X button
|     |-Circle = map a keyboard button or input device to the psp`s O button
|     |-Left Shoulder = map a keyboard button or input device to the psp`s Left Trigger
|     |-Right Shoulder = map a keyboard button or input device to the psp`s Right Trigger
|     Combo Key Configs
|     |-L + Square = map a keyboard button or input device to the psp`s Key Combo
|     |-L + Triangle = map a keyboard button or input device to the psp`s Key Combo
|     |-L + Cross = map a keyboard button or input device to the psp`s Key Combo
|     |-L + Circle = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Square = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Triangle = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Cross = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Circle = map a keyboard button or input device to the psp`s Key Combo
|     Combo Key Configs (with Direction Buttons set as Keys)
|     |-DPAD UP = map a keyboard button or input device to the psp`s Key Combo
|     |-DPAD DOWN = map a keyboard button or input device to the psp`s Key Combo
|     |-DPAD LEFT = map a keyboard button or input device to the psp`s Key Combo
|     |-DPAD RIGHT = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD UP = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD DOWN = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD LEFT = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD RIGHT = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD UP = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD DOWN = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD LEFT = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD RIGHT = map a keyboard button or input device to the psp`s Key Combo
| |-Misc = All uncategorized options
|   |-Mouse Speed = How fast you want the mouse, 1 to 5, 1 = Slow / 5 = Fast
|   |-High Res Mouse Speed = How fast you want the mouse in High Res mode, 1 to 5, 1 = Slow / 5 = Fast
|   |-Auto Mouse Speed = How fast you want the mouse in Auto mode, 1 to 5, 1 = Slow / 5 = Fast
|   |-Show LED's = Shows the Power, Drives, Frame Rate & Emulation speed
|   |-Transparent Keyboard = Lets you make the OSK, Solid or Transparent
|   |-Disabled Key Combo's = Turns off all key combo's, i.e. Screen move, will not work if this is "ON"
|   |-Toggle X & O = Use this option if you have a Japanese PSP, switched the X & O around
|   |-Background Image = Use this to turn Menu Backdrop "ON" or "OFF"
|-Configuration = Preset and saved config files
| |-QuickStart Config = Pre-setup Amiga Harware configs
|   |-Load Config A500 (OCS)
|   |-Load Config A600 (ECS Denise)
|   |-Load Config A1000 (OCS)
|   |-Load Config A1200 (ECS)
|   |-Load Default Config (Will load PSPUAE's bootup config)
| |-Load Config = Load your saved config files from the configs folder
| |-Save Config = Save your config files to the configs folder (Will use Floppy / state name)
|-Reset Amiga = Resets the Emulator (Use this when changing certain options or restarting)
|-Exit = Lets you quit the Emulator and go back to the PSP XMB
« Last Edit: July 21, 2007, 04:10:23 PM by Hungry Horace »
