Author Topic: PSPUAE Controls & Options Guide (17-08-2008)  (Read 22966 times)
« on: July 21, 2007, 04:03:31 PM »
*NOTE :- If you want to swap X & O (while using menu), you can swap in the Misc Menu.
PSP KEY Controls Default (In Emulation)
TOP LEFT TRIGGER = LEFT MOUSE BUTTON
TOP RIGHT TRIGGER = RIGHT MOUSE BUTTON
D-PAD = JOYSTICK0
ANALOG PAD = MOUSE
SQUARE = ACTIVATE KEYBOARD
CROSS = JOYSTICK0 FIRE
CIRCLE = RIGHT MOUSE BUTTON
TRIANGLE = HI-RES MOUSE MOVEMENT (Lets you move mouse more precise)
HOME = EXIT to PSP XMB
SELECT = OPTIONS MENU (Tweak Settings)
START = SCREENSHOT (Takes a screenshot)
PSP KEY Controls Default (In Emulation (Quick Config Keys))
L+R+DPAD UP  / L+R+DPAD Down      = Zoom  In / Out
L+R+DPAD Left / L+R+DPAD Right    = frameskip  Down / Up
L+R+ANALOGUE STICK                = Move Screen
L+R+TRIANGLE          = CPU Speed
L+R+CIRCLE         = On Screen LEDS
L+R+SQUARE         = Floppy Drive Speed
L+R+CROSS         = MouseStates Menu
L+R+SELECT          = Auto Zoom On/Off (If Off, then its Screen Lock On/Off)
PSP KEY Controls Default (In Menu)
TOP LEFT TRIGGER = SCROLL UP FAST
TOP RIGHT TRIGGER = SCROLL DOWN FAST
D-PAD = SELECT OPTIONS / CHANGE SETTINGS
CROSS = CHANGE SETTINGS
CIRCLE = GO BACK 1 MENU / EXIT MENU (IF IN ROOT MENU)
SELECT = EXIT OPTIONS MENU
PSP KEY Controls Default (In Keyboard)
D-PAD = HIGHLIGHT KEYBOARD KEYS
Triangle = Move Keyboard (Top or Bottom)
SQUARE = DE-ACTIVATE KEYBOARD
CROSS = SELECTS HIGHLIGHTED KEY
CIRCLE = ENTER / RETURN KEY (SAVES YOU HAVING TO MOVE AND HIGHLIGHT ENTER / RETURN)
PSP KEY Controls Default (In MouseState Menu)
D-PAD = HIGHLIGHT REQUIRED STATE
Triangle = DELETE CHARACTERS (While Keyboard Active)
SQUARE = ACTIVATE & DE-ACTIVATE KEYBOARD
CROSS = SELECTS HIGHLIGHTED MOUSESTATE & Keyboard KEY (When Keyboard Active)
CIRCLE = EXIT MOUSESTATES (When Keyboard not Active)
Options and What They Are
TOP MENU
|-States = SaveState Options
| |-Load State = Lets you load your Saved State (By name or 1 of 5 Slots)
| |-Load State By Name of state or 1 to 5 (in state folder)
| |-Save State = Lets you save your Saved State (By name or 1 of 5 Slots)
| |-Save State By Name of Floppy in drive / state or 1 to 5 (in state folder)
|-Drives = Menu for floppy Drives
| |-Insert In DF0: () = .ADF Dir on MS (lets you choose .adf`s / Zip`s from DISKS folder)
| |-Insert In DF1: () = .ADF Dir on MS (lets you choose .adf`s / Zip`s from DISKS folder)
|-Amiga = All Amiga related Hardware Options
| |-CPU
|   |-CPU Type = What type of Amiga CPU to Emulate
|     |-68000 = A500, A500+, A600, A1000, A1500, A2000, CDTV
|     |-68010 = A500+, A600
|     |-68020 = A1200, CD32
|     |-68030/68881 = A2500, A3000, A3000T, A3000UX, A4000
|     |-68040 = A4000, A4000T
|   |-CPU Cycles = How many cycles the Emulated CPU uses
|     |-Normal = 512 CPU Cycles
|     |-Turbo = 256 CPU Cycles
|   |-CPU Cycles Option = Stops CPU Cycles being accidently pressed
|     |-Locked = Locks CPU Cycles option
|     |-Un-Locked = Unlocks CPU Cycles option
|   |-CPU Speed = How fast to run the Emulated CPU
|     |-Max = Run CPU Emulation as fast as possable
|     |-Real = Runs CPU as if it were an Amiga
|     |-Chipset = Amount of time to share between CPU & CHIPSET (0% Chipset to 100% Chipset)
|                 This option, although gives speed increase. It can also slow GFX on screen
|-Chipset = All Amiga Chipset related Options
| |-Blitter Cycle Exact = Runs GPU as if it were an Amiga (Helps with compatability)
| |-Immediate blits = Runs GPU as fast as possable (Helps with compatability)
| |-Collision Mode = Screen sprite detection level
|   |-None = No detection will take place (Nearly everything will work with this set to None)
|   |-Sprites = Only Sprites are detected (Foreground, I believe)
|   |-Playfields = Only Background Sprites are detected
|   |-Full = Both Foreground and Background Sprites are detected
| |-Chipset = What Custom Chipset to use
|   |-OCS = A500, A1000, A1500, A2000, A2500, CDTV
|   |-ECS AGNUS = A500+, A600, A3000, A3000T, A3000UX
|   |-ECS DENISE = A500+, A600, A3000, A3000T, A3000UX
|   |-ECS FULL = A500+, A600, A3000, A3000T, A3000UX
| |-Sound Emulation
|   |-Sound Emulation = Sound Emulation type menu
|     |-None = No Sound Emulation
|     |-Intterupts = Sound Interrupts are emulated (This is needed for some floppies)
|     |-Normal = Emulated Sound
|     |-Exact = Sound is Emulated 100%
|   |-Snd Seperation = The amount of stereo seperation on Sound Emulation
|   |-Sound Delay = Gives a speed increase, by altering PSP Sound Delay
|-RAM = How much memory to emulate in PSPUAE
|   Memory On PSP FW 1.50 / Slim and Custom Firmwares
|   |-FastMem = Expanded Memory (Max 8192kb)
|   |-Chipmem = Graphics Memory (Max 2048kb)
|   |-Bogomem = Slow Memory (Max 1024kb)
|     Total = 11 Megs (Anything over 11 Megs can cause PSPUAE to crash, and using HD Floppies)
|-Kickstart = Amiga Kickrom (BIOS) selection menu
| |-1.0 = A1000
| |-1.1 = A1000
| |-1.2 = A500, A1000, A2000
| |-1.3 = A500, A1000, A1500, A2000, A2500
| |-2.0 = A2000, A3000
| |-2.04 = A500+, A2000, A3000, A3000T, A3000UX
| |-2.05 = A600, A600HD
| |-3.0 = A1200, A4000
| |-3.1 = A1200, A4000T
| |-Drives Config = How you want to setup the Floppy Drives
|   |-Floppy Speed = Normal (Speed of real Amiga) or Turbo (Double the speed)
|   |-DF0: Drive Type = Double Density or High Density
|   |-DF1: Drive Type = Double Density or High Density
|-PSP = All PSP related Options
| |-Display = All display settings
|   |-Direct VRAM Access = Accesses the PSP memory Direct (Can make small improvements)
|   |-FrameSkip = How many frames to skip in every render of screen (i.e. 0 = Every Frame rendered)
|     |- auto or 0 to 50
|   |-Zoom = Zoom function to help fill the PSP screen (some things can go off the screen)
|     |- 0%, 10%, 11%, 12%, 14%, 17%, 20%, 25%, 34%, 100%
|   |-Aspect Ratio = What aspect you want, either 4:3 (Square) or 16:9 (Regtangle / Widescreen)
|   |-Auto Zoom = It looks at the Amiga data (start / stop) that tell the sceen where to draw
|                 With this option "ON" Screen Lock is disabled
|   |-Screen Lock = If in 4:3 Zoom, you can move the screen position, with L + R Trigger
|                   + Analogue Stick, once moved you can lock it with this option
| |-Input Devices = User control setup
|   |-Controls = Main Peripheral Options menu
|     |-Analog Stick = map a keyboard button or input device to the psp`s analogue stick
|     |-Direction Buttons = map a keyboard button or input device to the psp`s joypad
|     |-Start = map a keyboard button or input device to the psp`s start button
|     |-Square = map a keyboard button or input device to the psp`s [] button
|     |-Triangle = map a keyboard button or input device to the psp`s /\ button
|     |-Cross = map a keyboard button or input device to the psp`s X button
|     |-Circle = map a keyboard button or input device to the psp`s O button
|     |-Left Shoulder = map a keyboard button or input device to the psp`s Left Trigger
|     |-Right Shoulder = map a keyboard button or input device to the psp`s Right Trigger
|     Combo Key Configs
|     |-L + Square = map a keyboard button or input device to the psp`s Key Combo
|     |-L + Triangle = map a keyboard button or input device to the psp`s Key Combo
|     |-L + Cross = map a keyboard button or input device to the psp`s Key Combo
|     |-L + Circle = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Square = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Triangle = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Cross = map a keyboard button or input device to the psp`s Key Combo
|     |-R + Circle = map a keyboard button or input device to the psp`s Key Combo
|     Combo Key Configs (with Direction Buttons set as Keys)
|     |-DPAD UP = map a keyboard button or input device to the psp`s Key Combo
|     |-DPAD DOWN = map a keyboard button or input device to the psp`s Key Combo
|     |-DPAD LEFT = map a keyboard button or input device to the psp`s Key Combo
|     |-DPAD RIGHT = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD UP = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD DOWN = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD LEFT = map a keyboard button or input device to the psp`s Key Combo
|     |-L + DPAD RIGHT = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD UP = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD DOWN = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD LEFT = map a keyboard button or input device to the psp`s Key Combo
|     |-R + DPAD RIGHT = map a keyboard button or input device to the psp`s Key Combo
| |-Misc = All uncategorized options
|   |-Mouse Speed = How fast you want the mouse, 1 to 5, 1 = Slow / 5 = Fast
|   |-High Res Mouse Speed = How fast you want the mouse in High Res mode, 1 to 5, 1 = Slow / 5 = Fast
|   |-Auto Mouse Speed = How fast you want the mouse in Auto mode, 1 to 5, 1 = Slow / 5 = Fast
|   |-Show LED's = Shows the Power, Drives, Frame Rate & Emulation speed
|   |-Transparent Keyboard = Lets you make the OSK, Solid or Transparent
|   |-Disabled Key Combo's = Turns off all key combo's, i.e. Screen move, will not work if this is "ON"
|   |-Toggle X & O = Use this option if you have a Japanese PSP, switched the X & O around
|   |-Background Image = Use this to turn Menu Backdrop "ON" or "OFF"
|-Configuration = Preset and saved config files
| |-QuickStart Config = Pre-setup Amiga Harware configs
|   |-Load Config A500 (OCS)
|   |-Load Config A600 (ECS Denise)
|   |-Load Config A1000 (OCS)
|   |-Load Config A1200 (ECS)
|   |-Load Default Config (Will load PSPUAE's bootup config)
| |-Load Config = Load your saved config files from the configs folder
| |-Save Config = Save your config files to the configs folder (Will use Floppy / state name)
|-Soft Reset = Resets the Emulator (Use this when changing certain options or restarting)
|-Hard Reset = Restarts the Emulator (Needed after changing Cycle unit and can increase overall speed)
|-Exit = Lets you quit the Emulator and go back to the PSP XMB
« Last Edit: August 17, 2008, 10:42:04 AM by FOL »
