Author Topic: WinUAE MMU setting  (Read 8314 times)
WinUAE MMU setting
« on: November 28, 2009, 12:16:43 PM »
never late.. i have old version.. time to update?
I would say so :)
You should use the stable 1.6.1 from the WinUAE site. You can try the beta after you tested 1.6.1 for a bit.
Beta works fine for me.
Offtopic sort of: Anyone know how to disable MMU completely, i.e. emulate the CE version of  the CPU's. I really need to do a test and need MMU disabled.
WinUAE MMU setting
« Reply #1 on: November 28, 2009, 12:20:50 PM »
on WinUAE i thought the MMU was only emulated in 030 mode?
WinUAE MMU setting
« Reply #2 on: November 28, 2009, 12:52:41 PM »
Well selecting 030,040,060 shows as full mmu.
I really need to test something without mmu.
WinUAE MMU setting
« Reply #3 on: November 28, 2009, 01:00:18 PM »
so why notuse an 000, 020 mode?
i think i must be missing something here.
TCD
  • Sir TCD of EAB
  • Backzorz wit da romzorz yo!
    • The English Amiga Board
WinUAE MMU setting
« Reply #4 on: November 28, 2009, 03:42:42 PM »
Not sure if it's even supposed to be active for 030. When you select 040 you can deselect the '68040 MMU' checkbox (which isn't enabled by default...). Honestly that would be a very valid question for Toni ;)
Re: WinUAE MMU setting
« Reply #5 on: November 29, 2009, 10:52:54 AM »
Ok, so my test may be working. So that means its all good. Will have to investigate further.
