Author Topic: CF to IDE / Amiga Harddrive  (Read 5353 times)
EmuChicken
« on: December 08, 2009, 12:29:32 PM »
Ok, Im looking into getting my amiga properly sorted by getting some external hardware for my pal amiga to japanese ntsc telly problem, but wanted to ask.... >
How much difference in performance does a CF flash memory thing > IDE actually give?
be nice to know  ;D   The adapters seem real cheap and itd be swish to get another slight upgrade to my amiga once its working properly again ;>
Re: CF to IDE / Amiga Harddrive
« Reply #1 on: December 08, 2009, 12:33:22 PM »
i have used CF-IDE on my A1200 for a few years now, and can say its fast, safe and reliable. i dont have figures for you though.
One of my favourite things about it, is that it's also silent.
oh yeah, and taking it out of the machine, putting it in the PC, and filling up with games is also pretty handy too :)
EmuChicken
« Reply #2 on: December 08, 2009, 12:41:09 PM »
Thats what I was kinda expecting...  is the speed really noticable?  -  I mean the speed that which workbench loads, or how nippy it is just in normal use?
.... I mean, would you say it was twice the speed of a normal chunky drive?
« Reply #3 on: December 08, 2009, 01:49:42 PM »
it's been so long since i've used an 'actual' drive, it's impossible to say.
« Reply #4 on: December 08, 2009, 03:40:40 PM »
I wouldnt have said its noticably quicker.
Now if you had a IDEFIX Express or Fast ATA connected then you would see some speed, ;).
« Reply #5 on: December 08, 2009, 05:11:05 PM »
i have 4xEIDE device, but i've had that since 1997 when i had a 'physical' drive also.
I also run SmartFileSystem on my CF and that helps.
« Reply #6 on: December 08, 2009, 06:58:53 PM »
CF ide 44 solution is much better than any HD disk ,easy,quick ,and absolutely quiet
