Pages: 1 2 [3]   Go Down
Author Topic: New Zealand Story Level Format investigation  (Read 18150 times)
Re: New Zealand Story Level Format investigation
« Reply #30 on: February 24, 2010, 08:23:05 PM »
errr...
     If LEVEL>0 and LEVEL<5 : Rem -- 1,2,3,4
      LEVELDATA=$18C80+((LEVEL-1)*$1600)
   Else If LEVEL>4 and LEVEL<9 : Rem -- 5,6,7,8
      LEVELDATA=$18C80+((LEVEL-1)*$1600)+$4200
   Else If LEVEL>8 and LEVEL<12 : Rem -- 9,10,11,12
      LEVELDATA=$18C80+((LEVEL-1)*$1600)+($1E400)
   Else If LEVEL>11 and LEVEL<16 : Rem -- 13,14,15
      LEVELDATA=$18C80+((LEVEL-1)*$1600)+($23C00)
   Else If LEVEL>15 and LEVEL<18 : Rem -- 16,17
      LEVELDATA=$18C80+((LEVEL-1)*$1600)+($30200)
   Else If LEVEL>17 and LEVEL<20 : Rem -- 18,19,20,21
      LEVELDATA=$18C80+((LEVEL-1)*$1600)+($3C800)
   Else If LEVEL>19 and LEVEL<22 : Rem -- 18,19,20,21
      LEVELDATA=$18C80+((LEVEL-1)*$1600)+($46200)
End If
you do the maths!  ;)
« Last Edit: February 24, 2010, 08:26:31 PM by Hungry Horace »
BooBoo
  • PSPUAE Moderator
« Reply #31 on: February 24, 2010, 09:34:04 PM »
ThankYou Sir :)
« Reply #32 on: March 07, 2010, 01:58:08 AM »
* Hungry Horace prods BooBoo
any progress mate?
BooBoo
  • PSPUAE Moderator
« Reply #33 on: March 07, 2010, 01:01:26 PM »
Hi - Hopefuly ill have some time to look I was just going to say before the MAP data there 2 figures that change the dimensions of the level - length,height.
Im using Disk.1 as a ADF now - zeroed all data that isnt Level 1_1 -Map tiles etc witch has clearded a lot of data, If you were makeing a game wouldnt you place enemies @ X,Y? but I guess thats not the point just have to keep looking :)
« Reply #34 on: March 07, 2010, 01:13:31 PM »
<snip>
if you change the width/height the exit/start points move, so clearly they are placed as 'offsets' from some point rather than fixed X/Y values based on the maximum level-size, i suspect the same will be true of the enemies
« Reply #35 on: March 30, 2010, 04:44:19 PM »
editor, source and a whole host of other crap attached for BooBoo!
BooBoo
  • PSPUAE Moderator
« Reply #36 on: March 30, 2010, 08:30:01 PM »
Thankyou Horace hopefuly I wont confuse my self to much :)
« Reply #37 on: March 30, 2010, 09:02:51 PM »
i cant rememebr how much i commented the source tbh
Pages: 1 2 [3]   Go Up
