Author Topic: Running PAL games on NTSC machines  (Read 7064 times)
EmuChicken
« on: January 20, 2010, 06:40:57 AM »
Ive got classicwb ADV SP working now, quite nicely...
just the goddamn NTSC "lack of lines" problem prevents me from "properly" playing some classics.
- It came from the desert, cant read what the other characters say...
- Sensi soccer, cant see the bottom goal...
- Super twintris, bottom is missing
- Super Cars 2, no health / position at the bottom
....  damn this sucks
« Reply #1 on: January 20, 2010, 08:30:41 AM »
can be fixed with a tooltype on the WHDload slave
EmuChicken
« Reply #2 on: January 20, 2010, 12:57:44 PM »
errmm...
can you give me the tooltype?
(the NTSC tooltype doesnt do anything other than speed up the game btw)
« Reply #3 on: January 20, 2010, 01:21:18 PM »
Funnily enough, i dont memorise all the tooltype numbers! ReadMe files are great things you know......
http://www.whdload.de/games/SuperCars2.html
- NTSC screen layout changed: Set CUSTOM3=1 to move the panel up a bit or
  use the keys +/- to switch the status panel during the game
EmuChicken
Re: Running PAL games on NTSC machines
« Reply #4 on: January 20, 2010, 09:56:31 PM »
OMG!  Im well gonna try that "move the panel up a bit" one ^-^
... FYI I did check out the whdload docs and couldnt find anything other than the NTSC tooltype,  Ill try the others once I get back from work (yeyeyeyey!)
« Reply #5 on: January 20, 2010, 10:27:54 PM »
... FYI I did check out the whdload docs and couldnt find anything other than the NTSC tooltype, from work (yeyeyeyey!)
i did specifically say it was just for Supercars 2
EmuChicken
« Reply #6 on: January 25, 2010, 09:22:55 AM »
it works now so I can "just" see the HP bar on my telly ...   ;D
- now the other games, but it might be best prolly investing in a scandoubler  :'(
