Author Topic: .adz games not loading  (Read 14003 times)
Barts_706
    • Barts' News - digital entertainment
« on: August 10, 2007, 05:08:14 PM »
I will double-check the adfs and send them to you, but I am at work now and going to my parent's place for the weekend after that, so it will probably be Monday 'till I can do that (no net connection there).
Okay, got them. These are the ones that don't load.
« Reply #1 on: August 10, 2007, 05:31:05 PM »
Great, ill check em out, when i get chance, just gone abit nuts at the moment.
bodhee
« Reply #2 on: August 11, 2007, 01:42:42 AM »
amberstar would be great..best rpg ever..
« Reply #3 on: August 11, 2007, 12:05:13 PM »
Errmmmm, these are .adz? They wont work, you need .adf.
At present, only .adf is supported fully.
« Reply #4 on: August 11, 2007, 12:35:59 PM »
actually i think that was fixed ages ago FOL
adz's are just renamed zip files, and zipped adfs are supported fine. I'm am pretty sure thinkp or ric or someone realised this and  gave adz support ;)
« Reply #5 on: August 11, 2007, 12:43:20 PM »
Ermmmm, horace, your confusing things, IT IS NOT SUPPORTED. .adf in a ZIP FILE is supported, but not .adz, just like .dms is not supported.
« Reply #6 on: August 11, 2007, 12:50:37 PM »
since you must of missed part of that ^^ i'll try again
ADZ is a RENAMED zip file!
you know... changing the .zip extension to .adz ?!
edit: if you dont beleive me, rename the wolchild1.adz etc to wolfchild1.zip and open it! you'll find it contains wolfchild1.adf - i just have!
thinkp added support by making it treat .adzs in exactly the same way as .zip
dms is completely different, but adz is not
« Last Edit: August 11, 2007, 12:59:25 PM by Hungry Horace »
« Reply #7 on: August 11, 2007, 01:17:57 PM »
Aye, sorry, must have missed that 1. Maybe theres a bug in source causing porblem, cause i use both adf and adf's zipped and all work fine.
Barts, are you using turbo or normal for drive speed?
« Reply #8 on: August 11, 2007, 07:38:39 PM »
Will try to look at this in the week. After what horace said, i checked and it should be working. Does it work with last version?
Barts_706
« Reply #9 on: August 12, 2007, 04:46:22 PM »
All right, I am waiting for the results. Yes, I checked it in 0.63.
I also downloaded some regular adfs from net and it doesn't work either - this time it just hangs after the trainer screen. I can upload them here too. Maybe it would just be easier if you created some working SaveState and posted it here?
On a sidenote, I wrote about the newest version of PSPUAE on my gaming blog :
http://www.bartsnews.net/2007/08/emulating-amiga-on-psp-with-pspuae-063.html
« Reply #10 on: August 12, 2007, 05:46:03 PM »
Check your comments, ;). The kids want my PC for the next few hours, but ill try and have alook at these disk loading problems later. Also i will try and finish the Wolfchild savestate tonight.
Barts_706
« Reply #11 on: August 13, 2007, 06:16:59 AM »
Thanks for the comments!
And I managed to find a working .adf version and I will upload states here, if only I have the right to do this in the other thread.
They can't stop the signal, FOL.
(sorry, couldn't help it)
« Reply #12 on: August 13, 2007, 05:22:47 PM »
No point in uploading normal, we only upload RAM Installed States, unless you have made 1 of these, then maybe you could join the R.I.S.S. Team?
« Reply #13 on: August 13, 2007, 08:43:35 PM »
you nesting enough quotes there FOL?  :o
« Reply #14 on: August 14, 2007, 09:34:28 AM »
Aye, didnt want to loose sight of what we were discussing, :).
I have been playing with the source, in between the kids highjaking my PC, ;). I havent got a fix as yet, aint had really enough time to full deep into it.
